Here’s the latest. Got some primo advice from Ryan Apple about welding, and I tried to weld. Got some boxes checked in the process, brake line tab on the axle, patched a hole in the floor...
Yes it does end. I bought mine in ‘91 as as $1250 beater. I put about $1000 a year into it for the next 10 years. In the next 17 years I’ve had to replace the tires and change the oil... other than that I’ve spent about $100 a year. After 28 years and 100k miles, it’s due for some body work, but the body was worse when I bought it in ‘91.Does it ever stop? I've had it in for suspension and tires, then A/C stopped working, needed battery o.k., then aa new starter, radio lost it's display then took it to the paint shop which it needed, started to really enjoy it (no bills, just driving it) then it started leaking oil on the PO rebuild engine, shop said they thought they found it (oil sending unit), drove it home and found oil under it the next morning, BACK to the shop, plus I noticed a little water under the A/C unit on pax side. They noticed the tie rods needed replaced which has helped with the steering play. So I can understand it's 38 years old and might have a few things worked on, but then the pax's side seat belt anchor came apart on my wife. So I'll say it again, does it ever end? Thanks I feel better.
They are incredibly built machines... most of what needs to be done is catching up on deferred maintenance and neglect. Once you get things brought up to your standards, it’ll slow down to a trickle... and then it’s the things you choose to do. The personalization and customization may never end.
They’re not like some other vehicles that spend more time on a hoist than on the road. A colleague of mine told me that at his previous job they joked they’d never be out of work if you have customers that drive a Eurovan... and they’d always hope that the owner managed to get off the lot before something else broke.
Hope I haven’t just kicked a hornets nest... no personal experience with one.
When I owned a ‘71 Triumph GT6, I heard it said that they (old Triumphs) were only as reliable as the mechanic who worked on them made them. Mine, even though it was a $400 basket case that had sat for over a decade, only ever let me down once. It broke down on after I put off fixing a clunking U-joint for weeks and kept driving it. Despite their reputations (ie the Lucas intermittent electron) it was just as reliable as a new car. So it’s all about how you take care of your ride. In its case... a Toyota Landcruiser alternator and some careful soldering of lights and redundant ground wires also made a big difference.
Had my buddy work on this for my 6014 winch plate. Lost the circle and made the TEQ a bit bigger. Sending to sheet metal shop Monday to get cut out.
Yes thought the same thing. Like the way yours turned outI like it! May add a red plate behind the TEQ on mine to make it stand out more.
View attachment 2390001View attachment 2390049
Attempted to burp the radiator, then gave her a rinse. Insurance purchased, trip permit should be here Tuesday...
Need to trim those ubolts!
View attachment 2390849View attachment 2390855View attachment 2390856View attachment 2390858View attachment 2390860
If it stops leaking oil, I know it’s past time to add more...Does it ever stop...[edit]..., started to really enjoy it (no bills, just driving it) then it started leaking oil. So I'll say it again, does it ever end? Thanks I feel better.
