They also cost an absolute fortune to ship! $455 was the quote I got to PA.
Wow! Mine were only around $180 to ship, though I also live a few miles from a UPS depot.
Thx. I’ll check the space. It would go in place of one jerry can inside my Slee, 3-can basket. Prob not enough room but I’ll measure & post.
Edit to @TonyP -Max footprint of 14.25”x7.75”
Other alternative is almost doubling that to 14.25x14.0” taking the spots of 2 cans, keeping only one on my bumper for quick use, faucet, etc...& other 2 inside, lower & centered between axles in second row.
If anyone knows of a 14x14” footprint weather-proof-kid box about the height (or a bit less) of a jerry can...I’d love to know.
Correct. Powdercoat.@Recon Aircrew - I use the Metaltech sliders on my 100 and they hold up very nicely to rocks and trees. It looks like you went with a powdercoat over traditional paint?
@Markuson , what happened to your TrekBoxx? I must have missed that discussion.Went through my drawers and side fit kit spaces to work on reducing weight.
Believe it or not...I dropped a good 35lbs...despite how FULL my drawers are in pic below. Main reduction was in heavy tools, redundant smaller items like sockets, liquids and items I had accumulated amongst similar, small items (bolts, etc).
The space they used was replaced by lighter stuff I always have on trips anyway, but scattered in other bags I end up digging through. So now saving the space those bags won’t take, and keeps drawers full enough to be silent/motionless inside.
Weight efforts will continue...
Hoping to replace one of my 3 water cans with lighter recovery stuff in its place on my swingout. So much water weight there not good.
Maybe something as simple/cheap as this large ammo can I saw today on a nicely built 4Runner- would be super handy, and keep a muddy rope outside after messy use...
That looks nicer than any ammo can I’ve seen!
But I’m actually not needing a jerry can to fit inside it.. It just needs to be the same bottom dimensions of a jerry can so it can squeeze in place of if of my three jerry csns in my 3-can basket.
Might need to break down have make a custom size basket made to accommodate larger ammo cans like that one.
Hmmmm... Wheels turning
Thanks @TonyP!
Got the lift installed this week I was afraid 2" wasn't going to be noticeable. I was wrong.
I'm going to stick with these for right now. But will definitely be going with a mud tire next time just not sure which one.Looks great. Are you going to size up the wheels and tires, or stick with those for now?
Have you thought about these? Rampage Jeep Products: Trail GearThat looks nicer than any ammo can I’ve seen!
Thanks @TonyP!
I have the open container one mounted to my bumper. (I painted it silver).
The one I have is just an open can. The top swings open, no drawers or hinged front panel.Yes, but since it needs to sit in a basket, though, I’m hoping for a top-access-only unit. Just want to be able to pull recovery straps out quickly without having to remove can or the seals that secure it.
It’s more a size constraint. Eventually, a different basket or a modified basket will do the trick.
Was hoping to get lucky and find something that would fit without modification...but probably pipe dream.
I believe @Markuson is referring to the location directly in front of the seat, right below the drivers knees.@Markuson so there by your right knee on the side of the center console is what you are suggesting?
I thought about initially doing it by the passenger left knee but that didn't seem like it'd be an easy grab in case of emergency. I tested as if I needed it from the rear of center console and didn't seem too bad
Didn't think about gear and other aspects that you mentioned..
