If I ever can get a 200 (see signature), toss up between while, gold, silver. If I could ever find one in blue i'd be on it...
Looks to be an active week or past couple weeks for a lot of us. At some point I'll consolidate everything I've done but for now... these past two weeks I finally got to swap my suspension. Did the work myself with help from @chap79 and a big assist from @RET2 who lent me one of those new Milwaukee cordless impact wrenches, can't say enough good things about that tool. I think I underestimated the project, I worked a couple hours a day mid-week and went at it hard for a weekend. Initially felt like I was in a fight with a razor blade against a guy with a machete. I've never done anything like this, even though it's pretty much "bolt off/bolt on" I still ran into hiccups and needed some liquid courage along the way. I suppose it really wasn't that bad in the end, but just make sure you have all the proper tools (I know crazy concept) and there are a few spots along the way which are a PIA (ie... fitting the LC stabilizer links into the Tundra LCAs, and reconnecting the stabilizer bar/links via messing w/ the KDSS hydraulic pumps, and the UCA through bolt took a bit of finagling, especially since I have the Slee primary tray installed which had to come out). I only lost one bolt that I had to replace. I also took the time to do a baseline of maintenance (sitting at 86k) since I'll be heading out to Cruise Moab at the end of the month.
Scope:
Holding judgement on ride quality until I can get some time behind the wheel but so far in limited action me likey.
- Front suspension - OEM Tundra IFS parts, Total Chaos UCAs, Bilstein 6112s
- Rear suspension - Fox 2.0 IFP shocks w/ OME 2721 springs
- Tough Dog adj. rear pan hard bar (got my rear to dead even)
- Crown SS brakelines - front, rear, rear drop lines
- added matching spare
- Maintenance: oil/filter, lube, rear diff oil, transfer case oil, front diff oil (pending because of stripped plug, gotta thank previous mechanic for that one), engine air filter, cabin air filter, bleed brakes, alignment
- wash and wax
Someone recently posted a thread about how it might not be KDSS fault, and might just be tired springs. Well even at 4 years old I think I had some tired springs, had a pretty good lean both right to left and front to rear. I tried every KDSS trick I could get my hands on and nothing got me close. After lift I am dead even left to right and nearly even front to back. Also to note, my suspension settled 1" in front and .5" in rear within the few days it was sitting finished in the garage prior to alignment. I did jounce it a bunch and loop the cul de sac a few times. So far I've gained 3.5" in front and 1.5" in rear, and I expect this to come down a bit over the next few weeks.
First thing I had to do was purpose an old costume, served as a perfect mechanic suit.
Then I got to work.
View attachment 1438335 View attachment 1438334
All-in adding all additional hardware, parts, tax, and alignment per scope above I'm at $3k on the nose. Of that amount, the OEM Tundra parts added $700 to the cause (I searched hard for "new" take-offs and saved myself a bunch going this route, pay through dealer and those Tundra parts are at least double). The Total Chaos UCAs were also a big expense at $750. If anyone wants sources for any parts/specific costs just PM on the side.Ho
Roughly how much do the parts for this lift setup run?
Ordered one of these as the first piece of the power puzzle. A killer deal popped up so I jumped on it. It's a 2000W (3400W surge) inverter/charger/auto-switcher all in one. Roll up to a campsite, it'll charge the spare battery off of shore power and/or use shore power to power everything. Unplug it, it reverts back to battery power. Pretty cool device. I just need a place to mount that big bastard. Also, I did NOT pay anywhere near $1300 for it.
Inverter Charger IC Series | Go Power!
Received this today. It's a big bitch. I'll need to be creative with the mounting situation. Probably at the rear of the drawers. I doubt it'll fit in the cubby on either side of the drawers.
That's why I went with the 1500 Watt version from GoPower...because that one was SO dang huge.![]()
Reminder: Make sure you run the most MASSIVE wire gauge you can possibly squeeze through your firewall, with the shortest length possible...with the biggest connectors you can fit...or voltage drop will be a problem.![]()
I'm thinking of mounting the batteries (two group 31s) in the spare tire area to minimize cable length to the inverter. I have a spot in mind I just need to get eyes on the location to see if it's feasible.
RLCA skids and front tow points arrived from the cutters.
200 Series Front Tow Mounts
200 Series Rear Lower Control Arm Skids
Do you sell the mounting bolts with the front tow mounts?
No I don't.
Size- Grade 10.9 or 12.9-- M12 x 1.25 x 40mm or longer for those that need to source new ones.
J
Installed the IBS dual battery system along with a Optima Yellow Top using Slee's battery mount. No electrical fires or anything, so I guess it was successful
