I got the final prototype of the rear antenna and light pod mount installed and these have been ordered and will be available in the next few weeks.
@savirc
J
Blech.
On the plus side, CRC now makes a cute little kit that has a small bottle of MAF cleaner and similar bottle of throttle body cleaner, $9 from Amazon. I use a K&N filter and the conspiracy theorist in me wonders if the oil in that doesn't pass through to the MAF and throttle body and dirty them more quickly.
Blech.
TM, I also wondered if the K&N was allowing oil into intake. I was told by a master mechanic, "if oil gets on the MAF it would cause problems", which would most likely result in a CEL. Over the years I was careful not to "over oil" the filter. I also would check the MAF for oil, by swabbing with a Q-tip. I never found any oil of any significance. Meaning the Q-tip cotton was not oily after lightly swabbing the MAF wires each ~20K.
That said I stop using the K&N air filter after reading this independent report: Filtration Testing for Amsoil, K&N, Napa, Jackson Racing, Baldwin, and Mazda air filters on a Miata
Blech.
I had the same thought on the oil from K&N passing into the TB. But I dont believe it does. Check the top of the filter box & opening of the intake tube nearest the filter for oil build up from the filter. That might point to blow by from the filter ( or not).
I have been running at the OEM Toyota filter, and have the same build up on the throttle plate; and I keep my filters clean/changed and use silicone grease on the edge filter seal to make sure there is nothing seeping by the seal surface. That build up may be leaking in through the o-ring at the MAF sensor, or the connection at the TB, or one of the vacuum lines on the sound resonator. FWIW I run a K&N in my RAM1500 and the TB is pretty clean, as well as the MAF, leading me to believe the K&N may not be your culprit.
That said my opinion is based on the K&N as it came out of the box pre-oiled. if you have washed your K&N and re-oiled it; and if you laid the oil on heavy with out letting it soak in and dry for a few days before installing, its plausible that some blow by oil has built up in that throttle plate.
With K&N filters and the fact people re-oil and clean their own, you can actually overoil and cause oil to penetrate the filter and cause MAF issues. It kept popping up on FJC forums when I used to own a FJC. The issue would go away with regular cleaning of MAF.
Oh, it's just the paranoia in me, I know it's not. There's no oily residue in the intake tube, that's the first place it would be. The MAF was clean when I pulled it and the gunk on the TB is all from the exhaust gas and unburnt fuel.
Esme didn't sell yet? How is that possible?
I took her off the market... Too many tire kickers! I'll keep her and when I get finished with my other rig--100/105 conversion-- I'll sell her for $5-7K more than my fire sale price.
J
Damn. Hard to believe!
Installed new boots.....285 75 16
Did an oil / filter change at 150,279 miles (13,236 on the oil / filter) and sent a sample to Blackstone Labs.
So what parts exactly are included in a 105 front clip?
C,
front frame section, radius arms, complete front axle/housing, motor mounts, all steering links/rods, coils, shocks, (RHD) steering unit, pump, brake lines, etc.. I'll use a 80 steering unit more than likely.
Plan is to design a front clip mod for the guys that want it. Complete kit with new suspension. Connector plates, cut templates, steering kit, etc..
J
*not a 105 clip-just a reference pic*
C,
J
I shouldn’t have even asked, but you see, I did. Sounds cool! ;)
