Here I thought I was going to use this header with the old intake. But I'm getting close to the point of mounting this so as I went to align it it looked like this like it's not going to work. Do I need to start cutting or find a different option?
Seen as how the intake and exhaust came off and it was all period correct for a California smog vehicle, I'm pretty sure this intake and exhaust came stock with this motor. The header is the unknown variable that came with the truck but again was a third-party option that the previous owner never got the chance to install.You definitely don't want to modify or cut away at the intake manifold with the holes only being partial, to begin with. I would talk with the supplier of the header and make sure it is the correct one for your application. I would verify your intake manifold as well, is it the correct one for your engine? Possible that the header flange was laser cut / machined wrong as well.
I'm installing 3FE exhaust manifolds and F intake manifold on the '76 2F in my '71 FJ40.
I got some used 3FE flange/downpipe sections here on MUD. I'll take the '71 to the same shop that did the custom exhaust sections for my '86 FJ60 with 3FE.I'd like to install 3FE exhausts on mine some day too. I had some, but gave them away some years ago.
Can you use 62 or 80-series down tubes and y-pipe, or are you just going to make custom ones?
What is the advantage of the F intake manifold? Simplicity I assume?
