What do I do now?
I got some used 3FE flange/downpipe sections here on MUD. I'll take the '71 to the same shop that did the custom exhaust sections for my '86 FJ60 with 3FE.
The F intake manifold was on the '76 2F in my '71 when I bought it over 20 years ago, along with the F carburetor. I like the F carburetor over the later ones because they're simpler. And it has the advance port added, which is needed for the FJ60 distributor's vacuum advance. I swapped a spare FJ60 air cleaner for a '76 2F air cleaner. I like it because it has the hot air intake, which will be good up here in the mountains during the winter months. I bought an extension from City Racer so I can use the F carburetor with the 2F air cleaner. In order to avoid the interference between the early throttle cable's loop and the 2F air cleaner I bought a '73 carburetor/throttle cable linkage from @65swb45 and an aftermarket throttle cable assembly from @Downey. That set-up seems to work well.
Thanks for the info. I am running an FJ60 distributor also, and a less-than-ideal '79-80 carb that I would like to replace with a Holley Sniper some day.
Maybe there's a better oem exhaust manifold?
@65swb45 probably has good information.
Aaron and I already spoke about his options yesterday . He was kind enough to put a few extra dollars in my PP account for consulting too. ;)
New information because I started inspecting it to reinstall the old manifold. It has a crack. Also there's something else leaking out exhaust given the black color. I'm leaning more to cutting from the intake now to mount my headers.
Btw pretty sure they were Downey given that I also found these.
airon - try hanging the intake and the exhaust on the mounting studs. Mu header was similar to yours but was able to stretch them with little effort to fit well once they were on the studs.
I would NOT do this.
The header tubes on those headers are not mandrel bent, which means the tubing wall is stretched thin in the radius bends...right next to where they are welded to the flange. Distorting the flange will put pressure on the thinnest part of the tubing wall and insure you crack tube(s) prematurely.
I measured with a micrometer, or caliper, the thickness of a couple of 2F intake manifolds and found that their tabs were consistently 10mm thick. How does yours measure out?
Also, does your manifold gasket match with the header? No point using equipment that requires non-reversible mods to fit, creates restrictions, or is subject to leaks.
