While I'm waiting on my bumpers from Luke, this is what I'm doing in my 80's that run 35's:
View attachment 1201434 View attachment 1201435
The seat mounting bar and the floor tie down points allow the two lower ratcheting straps to really grab on tight. The upper strap to the grab handle is there just for a little top control.
I did this same thing years ago before I had my rear bumper. Maybe I had the straps a little too tight but after a few hours on the trail I noticed it had started to pop the side window out. About 1/3 of the window had pushed free of the channel, gasket and all. Just keep an eye on it.
It sucks. "Someone" needs to make a relocator. :hmm:
How often does it need to be replaced? My truck has ~280k and no idea when/if it has been changed. I am replacing it while doing a plenum cleanup as a "while I am in there...." item in the coming weeks.
Pretty sure its supposed to be every 25k. But I'll need to check out the manual again to be sure. I'm really bad at replacing these at appropriate intervals.
I'm at 10x that interval! I guess I should do it someday...
My 60 is carbureted and has the see-thru inline filter. It takes no time at all to get that thing dark and gross looking. On that truck the fuel filter can be a source of fuel issues so I keep on it. Now I imagine what the fuel filter looks like and it's been 50k so far since I've touched it. But I've also never opened one up and I'm curious.
I removed the starter on my 80 to inspect the drive plate. Turns out one of the tooth is chipped which could explain the reason why my starter makes a clunking noise when cranking it up.
Sent from my iPad
Sunset on the south shore. Nice way to close out the weekend....even nicer when its only a 2 minute drive in the Land Cruiser from my house.
I really can not wait to get back to the Islands. It would be even better to be on the Islands with a cruiser.
Not the weekend but my 14 year old son was home sick from school today so it was an extended weekend for him. He texted me to google "why are jeeps" and "why are land cruisers". So I did. I sent him the screen shots of what my results were. His reaction is classic. I've raised my son well.
HA HA. They are "So expensive" because they are "So reliable"
Fun! I tried the same thing with Iowans...Google never lies!
I bought my 80 a few months ago. Since the purchase I have been working on it non stop for the last couple of weekends trying to baseline and improve on it. Thanks to the many great "how to threads", vendors and fellow members selling items I have accomplished the following. I still have many more things planned for it.
Front axle rebuild with switching of joints
New front rotors and 100 series pads
New distributor "O" ring
New spark plugs
New spark plug wires
New cap and rotor
New air filter
New alternator idler pulley
Changed all fluids
Pcv valve and 2 hoses
New CDL switch and pin 7 mod
New tires
New Egr vsv (Due to P0401)
New vacuum hoses
Cleaned throttle body and installed new gasket
New accelerator cable
New fusible link
PHH bypass kit
New oem radiator
New thermostat and gasket
New silicone radiator hoses
New belts
New fuel filter
New slee belly pan
New TRE's
New Denso O2 sensors
New weather tech mats for first two rows
New coil
New rear rotors and pads
Metaltech Sliders
Replaced all rubber brake lines with the slee kits
Landtank MAF
Sealed oil pan arch seal
New blue fan clutch
New intake hose
New a/c idler bearing
Not my dd. I took 95% of the usable part's off first. Still :crybaby:
