60. 48 is barely adequate. That's what I have. Depends on your lift and whatnot of course.
Are you thinking about lifting the car up from a ditch or just a tire change, in terms of being adequate?
I've been a busy bee chasing a snap in the front end when its under steering load or articulation. Replaced the steering damper and bracket (original one was bent badly), I also replaced both ball joints with OEM joints on the steering tie rod... the snap is still there, I think it might be in the tie rod between the tires or a spring but IDK at this point. I might put the gopro under the truck and try to zero in on the issue. Its obvious that I still have some leaks huh?
I have the 48. Mostly because that's what I had with my FJ55 on 33s. And I'm cheap.Same debate going on here too.
60 inch is the way to go, especially if you have at least a 4 inch lift or larger and 35s. I have a 4 inch Slee and 315's on my rig now and when I was trying to lift it off of the ground, it was almost over half way up the Jack. You will need every bit of a 48 inch Jack to get a cruiser off the ground.Same debate going on here too.
Good question really. For general purposes a 48" would be fine 98% of the time.Are you thinking about lifting the car up from a ditch or just a tire change, in terms of being adequate?
YUP60 inch is the way to go, especially if you have at least a 4 inch lift or larger and 35s. I have a 4 inch Slee and 315's on my rig now and when I was trying to lift it off of the ground, it was almost over half way up the Jack. You will need every bit of a 48 inch Jack to get a cruiser off the ground.
I don't have that big of a lift.60 inch is the way to go, especially if you have at least a 4 inch lift or larger and 35s. I have a 4 inch Slee and 315's on my rig now and when I was trying to lift it off of the ground, it was almost over half way up the Jack. You will need every bit of a 48 inch Jack to get a cruiser off the ground.
The 48 is fine most of the time.Got the measuring tape out to estimate what lift I need.
The 48" lift only goes up to 37.5 - 38.5".
I have the ARB front bumper. If I get the "Lift-mate" attached to the hi-lift and the bumper, plus an estimated 4" suspension travel before the tire comes off the ground, I think I only have about 1" left for the tire to clear the ground. Of course these are rough estimates after 1.5 pints of Mojito.
I think the 60" would be better. Or get the Hi-Lift Jack Mate http://www.4wheelparts.com/Winches-...spx?t_c=18&t_s=190&t_pt=10044&t_pn=ARB3500040 or the Slee Jac-Kof Tool http://www.sleeoffroad.com/products/products_jackof_detail.htm
which both will give me more travel with the 48" lift.
This is all based on pavement of course. Off road things might changed a bit.
It's a $30 difference between the 48 and the 60... Get the 60" Hi-Lift X-TREME !!The 48 is fine most of the time.
I've been a busy bee chasing a snap in the front end when its under steering load or articulation. Replaced the steering damper and bracket (original one was bent badly), I also replaced both ball joints with OEM joints on the steering tie rod... the snap is still there, I think it might be in the tie rod between the tires or a spring but IDK at this point. I might put the gopro under the truck and try to zero in on the issue.<snip>
Let us know when you figure out what the noise is from. I've got a pretty serious clunk from my front end as well when turning (usually just when turning while stationary). I've checked the panhards, but I'll be checking the radius arms tonight.I've been a busy bee chasing a snap in the front end when its under steering load or articulation. Replaced the steering damper and bracket (original one was bent badly), I also replaced both ball joints with OEM joints on the steering tie rod... the snap is still there, I think it might be in the tie rod between the tires or a spring but IDK at this point. I might put the gopro under the truck and try to zero in on the issue. Its obvious that I still have some leaks huh?
I also replaced the lower control arms (bent the stock ones on the chinaman's gulch run) in the rear with some wicked SPC 3/16" DOM control arms from Mr. Slee they have ball joints on the axle side for extra flex. And my drivers side rear wheel bearings grenaded themselves so I am waiting on seals and bearings from Mr. T.
