great idea, thank you! how do the drawers work with no slides?
I used just wood wax for awhile, you. You can also use strips of plastic or Teflon. Slides great.
Now after you posted that, my cruise control decided to flake out on me. Not sure the issue yet.Took a drive today. The cable slack was my issue. I'll have to order a new cable
Not sure if this is related to your cruise control issue. I’ve been troubleshooting random no start issues, check engine P1780 code and no cruise control for awhile.Now after you posted that, my cruise control decided to flake out on me. Not sure the issue yet.
That’s a interesting coil spacer you have thereFinally got the spare parts and mechanic replaced the cluster poop that was the back beaks. (way too advanced for me XD)
New discs, master cylinders at the back, oil seals, break pads, new back disc cover with proper fittings for oil lines.
And yes gentlemen, i am one of the few LC owners who has a working hand brake !!!
It feels so weird when the car doesn't role when I pull the hand brake up!
is that the good interesting? or like most of the previous owners grand wisdom interesting ??
So add coil spacer on to do list then ... its actually coil spring buffers if i am not mistakenIt's interesting in that my mom said if I didn't have anything nice to say
Take it off and get it in a good upright position. The first time I left it on and you just can’t get a good enough angle to keep the paint wet as you’re working so the center of the hood comes out way too dry and like 40 grit sand paper. I had to block it back down with 800 and redo it.Getting ready to rattle can my hood this weekend. Any tips? Going with Automotive Specialists Base and 2K SprayMAX Clear.
Nice! But, just looking at those zip ties is making my hands bleed...Got the mounting bracket for the fill and drain hose fittings for my water tank mounted up today. The shore power plug for the NOCO charger is on there too. Lots of plumbing for the tank. Two sets of inflow and outflow hoses (one for the shower and filling it up and one for the heat exchanger) an air vent, a hole for the temperature sensors and a hatch in the top for access.
The zip ties are just holding it in place till I can get some stainless hose clamps on there. The pump in the housing isn’t wired up yet so I don’t have it locked down.Nice! But, just looking at those zip ties is making my hands bleed...
Do yourself a huge favor...
This great! Does it take all the space ? I have the sub fuel tank and 2nd spare tire and was thinking of removing the tire extending the fuel tank and adding a water tank as well.Got the mounting bracket for the fill and drain hose fittings for my water tank mounted up today. The shore power plug for the NOCO charger is on there too. Lots of plumbing for the tank. Two sets of inflow and outflow hoses (one for the shower and filling it up and one for the heat exchanger) an air vent, a hole for the temperature sensors and a hatch in the top for access.
