Thanks. I've had these stored in spare bedroom for several years. Bought from a guy on CL out of storage container. No hurry to replace so they just sat. I cleaned and treated the leather/vinyl. I did have to replace broken driver switch but it's good now.Seats look amazing @voorland80 what did you do to keep em so nice?
The Camry airbag has the same connector as the LC and plugs right in.
Clean
I have tried this set up everything works perfectly and you'll need the Camry airbag too, but the only thing I don't like is that the Camry steering is smaller than the land cruiser but never the less its a good fit if you don't mind a smaller steering wheel97-01 Toyota Camry steering wheel and air bag. Plug and play. There is a guy on eBay that sells new old stock on the wheel itself. Unfortunately his price went up recently from $69.00 to $109.00. Here are the items to make it work.View attachment 2290421View attachment 2290424
I could use the extra leg room at 6"6I have tried this set up everything works perfectly and you'll need the Camry airbag too, but the only thing I don't like is that the Camry steering is smaller than the land cruiser but never the less its a good fit if you don't mind a smaller steering wheel
That was my one hesitation but I figured that I’ll likely get my LC wheel rewrapped later on down the road anyway so this should work fine for now.I have tried this set up everything works perfectly and you'll need the Camry airbag too, but the only thing I don't like is that the Camry steering is smaller than the land cruiser but never the less its a good fit if you don't mind a smaller steering wheel
If I remember correctly the difference is only about a half inch. I liked the slightly smaller feel instantly but I am over 6’ tall so the extra room is nice.I have tried this set up everything works perfectly and you'll need the Camry airbag too, but the only thing I don't like is that the Camry steering is smaller than the land cruiser but never the less its a good fit if you don't mind a smaller steering wheel
Thanks on both.....sorry for such a delayed reply. Work has been super busy!Best color cruiser ever! Nice boat too!
Kit or custom?Boxed hinge for the swing out, and the tire carrier is coming together.
Now its a TO - Yoder!Picked up my seats. I had the Amish in TN redo them.
It's customKit or custom?
One thing I've been surprised kinda
Its tight for me upfront
If I'm not attentive my knee rests right on the OD button ...not good...killin my mileage![]()
Get outta town sir!Also 6'6".
If you havent done the seat brackets and removed your dead pedal you're missin out.
I felt cramped and now fit super well.
80 Series Seat Extension Bracket Kit
Are you planning on using a spindle or just that bushing/bolt setup? A tire carrier + tire is a lot of weight to support.Boxed hinge for the swing out, and the tire carrier is coming together.
There will be another hinge attached to the tubing above the taillight.Are you planning on using a spindle or just that bushing/bolt setup? A tire carrier + tire is a lot of weight to support.
