Crawled under the rig for something else only to see the PO's or his shop's handy work. Notice the bushing larger on one side than the other... 🤦🏻‍♂️
Swapped them from right to left and problem solved. Except I'd imagine those bushing may not last as long as they would've otherwise.
Was headed for a little off-road trip, but my radiator sprung a leak...since I’ve gotta wait for the new rad, water pump, and thermostat to get here, I figured I’d flush the Tranny and change the oil...of course it started raining as soon as I started:)
Got my winch installed finally. Also got the second battery I stall started. Just got to finish up the controller for it. Thanks @LandCruiserPhil for the battery hold down.. only took me a year to get around to it.
Was headed for a little off-road trip, but my radiator sprung a leak...since I’ve gotta wait for the new rad, water pump, and thermostat to get here, I figured I’d flush the Fanny and change the oil...of course it started raining as soon as I started:)
Hope you got your “Fanny” :rofl: flushed and all is well!
Pulled the cowl off to clean out leaves and whatever. Almost nothing in there except one small little pile on the passenger side. Changed out the cowl hood seal while I was there.
Spent the day enjoying the cruiser.
Ive been working on quite a few things the past couple weeks. Just finished up this weekend.
1: @Box Rocket (thanks for your help)
stage 4 slinky suspension, @Delta VS panhard bracket and new Icon extended break lines
2: @Delta VS center console. (No gauges yet, they are coming) installed a Baja designs dome light in the middle (perfect fit) hard wired everything to a blue sea box. Ham radio, 3 USB ports, dome light, red arc trailer brakes, Garmin overlander and InReach mini.
3: Baja designs rear hatch dome light
4: Massive metal shop antenna mount
5: red arc trailer brakes
6: Winch RPM adjuster
