- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 13,332
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Got those part numbers available? Yes, I could look them up too, but these are the exact two parts next on my replace list. Thanks.For the entire 80k miles I've owned the 80 washer fluid has squirted out of both ends at the same time. Finally replaced the diverter valve. Easy, quick, cheap. Why the hell did it take me so long?
Also replaced the "hose, ventilation #2" as I found a split in it on the back side where it couldn't be seen. Old one was so hard and brittle I was able to just snap it in two like a twig.
i see the pump and front seal part numbers, would you mind providing the dist oring number?
But of course, all in stock
We stock the bushings separate, the bushing/bearing combo separate or the full spindle with the pre-installed bearing/bushing. Most are available from us in OEM or aftermarket variants too
We stock the new variant spindles in both OEM Toyota and Joint Fuji Japanese too
As noted can actually use the long bushing in the new spindle and vice versa. There are a few out there that prefer the bushing only (Kevin RIP!!)
5 Aces and a palindrome odometer on Friday. (Yes, my dash is dusty).
He rubbed off on me. I prefer the bushing to the bearing, too.
View attachment 2197977View attachment 2197978
Two weeks ago we had a massive pile for the chassis build. Now it is down to brakes and sway bars.
Just waiting on a few parts to show up Monday and we will finish it off and bolt on tires.
Cheers
A bare frame and axles like that would be an extremely convenient time to weld the panhard mount, sleeves for the steering box bolts, front sway bar mounts, etc.
After 2.5 years in storage I finally had time to clean and warm up the engine been wanting to do this but was always busy and was thinking if I should sell or keep herView attachment 2198267View attachment 2198268View attachment 2198269
Nice but eh, I think you should sell it. Ill give you $5k for it.After 2.5 years in storage I finally had time to clean and warm up the engine been wanting to do this but was always busy and was thinking if I should sell or keep herView attachment 2198267View attachment 2198268View attachment 2198269
