Did a little exploring
Very cool. Looks great.Flush mounted a solar panel on a Bowfin rack. Props up on either side as well. @dogfishlake
Then went on a drive.
it is now marinating in a couple different penetrating oils. Guess its time to hook/wire up the compressor up and use the Air Impact gun instead of the Cheesy electric one. Breaker bar would not budge it, was trying to do it Solo! Added a scan gauge and mounted on the steering column with the mount found on Etsy.I took off the OBD mount and ran it under the dash with a splitter (I wanted to be able to have the fuse door on and I hate cable run over crap, It's stealth, and then put the spare one under the dash on the trailer brake controller. Sorry ran out of Daylight i' ll add pictures tomorrow, Damn Panhard bolt was pissing me off!So....would you do it yourself again or send it out to pros? I'm firmly on the fence with mine but leaning towards pros with experienced eyes (wear on parts, etc.).Finally finished rebuilding the steering gearbox. It turned into a right PITA.
I bought a used box from a mud member, and reworked it on a bench. I ended up having to replace the needle bearings for the sector shaft. Without the SST it was almost a disaster.
Finally got there in the end though.
You are a lucky man!
Solid feedback. I'm in that same camp but this dumb gearbox is making me question things. Thanks for your take on it!In general I am a DIY'er. That being said: if i were to do it again, I would still do it myself. I am not trying to maximize my profit on it, so anything that is questionable I will replace or renew vs letting it slide so I make a few more dollars on it.
I don't believe a for-profit biz would have replaced those needle bearings. Ultimately I feel I do a better/more thorough job if I do it myself, and I trust it more. Rebuilding the box isnt very technically challenging, but it does require patience and some creativity.
I am in the market for a rack and i like th eBowfin and spoke to the owner of Bowfin. Let me know how you like it and if you feel it is a solid rack! I only want to buy one!Flush mounted a solar panel on a Bowfin rack. Props up on either side as well. @dogfishlake
I’d buy one if I needed another.I am in the market for a rack and i like th eBowfin and spoke to the owner of Bowfin. Let me know how you like it and if you feel it is a solid rack! I only want to buy one!
I totally understand. I was comfortable doing it for a couple of reasons:
1) I rebuilt my '60 box already, they're almost identical
2) FSM & good threads on mud to guide me
3) I bought an extra from a part-out, so there was really no risk or downtime
I'd jump in and get after it, it's really not THAT complicated.
Good luck with whatever you decide to do.
Same question here.. Have 330k and a bit of a wandering sprite as well... I was planing to replace the bushings this summer..Does rebuilding the steering box return the steering to the tight configuration like when it was new? My rig has 280K+ and the steering has a tendency to "wander" a bit these days. It isn't dangerous but it is a far cry from my wife's 2007 LX which has about 90K on it.
Beautiful! Love the JDM fog lights.Went hiking/snowshoeing... Seemed like a cool spot on the road up the the trailhead so I stopped and snapped a pic of the beauty.View attachment 2200951
I keep a pretty close eye on all of these items and inspect them regularly as I typically wheel alone and don't want to get stranded. Everything mentioned above is tip-top. I have had the truck since 97 so I tend to notice when things change. It isn't a daily driver anymore so it simply doesn't get much wear and tear. I have pretty much narrowed it down to the steering box as it is the only thing I haven't rebuilt completely over the last few years. My question was whether this would tighten it back to stock and you have indicated above that it will help alot as long as everything else is in order. Really appreciate the in-depth answer! Removes any remaining mystery.@DannyG
In my experience "wandering" is more likely going to come from loose wheel bearings, loose/worn suspension bushings, steering rod ends, bad toe adjustment, a suspension lift without proper setup, poor/worn or mis-inflated tires and possibly bad shocks. Others can correct me if I'm wrong but a slack/worn steering box seems more likely to simply make the wandering more problematic since you have to move the wheel further, through the slack, to keep the truck tracking. If your truck wanders I'd start with inspecting your wheel bearings and rod ends for looseness. You can lay under the truck while someone wiggles the steering wheel back and forth and watch/feel each rod end for slack. Then, lift each wheel off the ground and push/pull at 12 and 6 oclock then 9 and 3 oclock to feel for wheel bearing looseness. Loose wheel bearings on the 80 seem fairly common, possibly in part as a result of the FSM torquing process, so I'd always check your wheel bearings if you have steering issues since they can be a way to get a quick improvement.
