Good lord “server error” = multiple posts
The caster plates aren't responsible for shortening your wheelbase - the wheelbase shrinks because of the change in radius arm angle due to the lift. It would happen with or without the caster plates. The Delta radius arms are longer to compensate for exactly this.Replaced the plates with Delta arms. My caster went from positive 3.75/4 to an even 4.25. I could feel the difference immediately.
I also got my stock wheelbase back as I noticed the plates shortened it enough for my wide 16x10 wheels on 35s to rub a tiny bit on medium lock going in reverse one side only.
I just wish the Delta arms were avail before I got the plates as the plates require you to cut out some metal on the axle. I’ll eventually weld on some steel to tidy it up.
Metal Tech caster plates for sale!
Oven set up works just like home. Bringing my trail cooking to a new level.
Pizza on the trail
LCP
Battery Bracket Upgrade Jack Adapters Mud Flap Eliminators Rear Heater Delete Hose Severe Duty Rear Sway Bar Links Severe Duty Front Sway Bar Mounts Shifter Extension Sway Bar Disconnects T-Shirts Window Modssites.google.com
Nice shirt.Oven set up works just like home. Bringing my trail cooking to a new level.
Pizza on the trail
LCP
I have to ask where I can get one of those shirts "landcruiser - becasue everything else just sucks" Love it
@nickolai Can you share manufacturer name and model on the battery? My vote would be create a new thread if you can with a few photos once you get the battery and bracket in. Thanks!
