Yes, even touched up outside of the air bag. Blends PerfectlyAh, so you painted the cover? I suppose you can then buy any wheel cover and just paint it? didn't think of that.
Mine is in terrible shape and my hands stick to it, feels gross.
That's quick work.... in the mud even. I love the "getRdone" attitude. You are destined for greatness. Have you started a build thread yet?
Was probably just clogged sun roof drain tubes. What type of sealant did you use?
There is a drain tube from each of the 4 corners of the sun roof catch pan between the roof and headliner.Where are the drains and how to you unclog them?
Any suggestions on how to unclog them? Thinking I should look into doing these before they become an issue.There is a drain tube from each of the 4 corners of the sun roof catch pan between the roof and headliner.
The front two are routed down the "A" pillars and terminate in the rocker panel. There is a tiny drain hole formed into the pinch weld there in the forward area of the rockers.
Both aft drain tubes are routed down below the cargo area windows above the wheel well and the tubes themselves poke out through the body just rear of the wheel wells.
If you have an air compressor blow the high pressure air through all the holes. Mine was leaking and this solved the problem for good.Any suggestions on how to unclog them? Thinking I should look into doing these before they become an issue.
It's time for new rotors and pads on the 93. What is the consensus on what to buy? I almost always stick with OEM but am open to alternatives. But not interested in breaking the bank. I've never replaced rotors before.
I'll definitely go 100 series pads as that seems to be the way to go.
I'm doing the knuckles and wheel bearings at the same time. Anyone want to come over and help!?!![]()
