Departure angle
My 4x4 labs measured 10" off the ground
Departure angle
Got started on the rear lower control arms.
Should have them finished and shipped by Monday.
J
Will ▲this▲ accept a factory bushing? If so it the part available over the counter or do you have it made?
That's what my cousin asked when he saw it in mine lolThats not the CDL switch, thats the Empire Tie Fighter switch, gives your 80 wings!
Just FYI, pin #7 is the BLACK wire with a BLUE STRIPE.Just to confirm....as there were 2 wires on the 7 pin harness that were black and blue....
It was like that when I got it. It bugs the crap out of me! I've tried cleaning it but it won't come off. I have a water bottle and bladder from a 91-92 (aka JSM washer bottle) that I'll be putting in at some point.
Big fyi! Found this out the hard way. Luckily I didn't cut it and just de-pinned it instead. Even luckier yet that I actually got it to push back in lol, I was sweating it there for a minute or two!Just FYI, pin #7 is the BLACK wire with a BLUE STRIPE.
The other one is BLUE w/BLACK.
Took the 80 over to Berrima Diesel yesterday morning.
Pulled a measly 68rwkw and came out with 113rwkw. Turbo is very loud now, probably a bit too loud for my liking...cruising back home on the freeway, it was louder than the 35" Muddies!
Yota master, the force is strong with this one.View attachment 1364040 Got this made for a 12 pack....of donuts!!
Next stop: Crank Seal town.
If it survives, it will be available to anyone in Bay Area that needs a torque multiplier and has a 1" od breaker bar. (For pick up only).
17. Replace knock sensors after accidentally breaking off connectors while doing steps 1-16.Big weekend planned.
1. Replace EGR VSV, repair wiring from my temp fix.
2. Replace all hoses under the plenum
3. Clean the upper plenum, it is filthy.
4. Clean throttle body, not too bad.
5 Replace the heater mixer
6. Replace all hoses associated with the heater mixer, phh as well since it is easy to get to right now.
7. Replace the valve cover gasket and reseal the half moons.
8. Replace the PVC, grommet and hoses.
9. Replace all vacuum lines and hoses.
10. Replace distributor and o-ring. I have an internal leak.
11. Replace the low pressure PS hoses.
12. Replace the oil pump cover gasket.
13. Replace the crankshaft seal.
14. Full cooling system flush, switch to green.
15. Replace the thermostat.
16. New plugs, rotor and wires.
I think that is all. I wonder if I'll be given a reprieve from normal weekend dad duties to do it all. I have everything torn down right now. I still need to go over to a friends house to make a holder for the harmonic balancer and I haven't looked at green coolant yet. Thanks to Joey and Onur.
BAMI may do that this weekend as well. Mostly I have to get my muffler hooked back up. Snowboarding on Sunday.
The lack of rust and enormous amount of BLM are awesome. Cali would be great if it weren't for literally everything else
The lack of rust and enormous amount of BLM are awesome. Cali would be great if it weren't for literally everything else![]()
Close.By BLM, you mean Bolt Length Matters? Bolt Lubrication Matters?
Blue Landcruisers Matter.Close.
Bolt Locktite Matters.
