On the '87 60...Finished a project that I started a few years ago....
Removed the 90s-era purple window tint.
I tried to use a heat gun when I first attempted this job. Didn't feel comfortable getting the glass so hot, so I parked the project and just lived with it.
Recently, my wife picked up one of those big garment steamers, so I requisitioned it off to my garage for a day or two.
Worked like a charm. Despite the film wanting to separate into two thin layers and tear. Probably 5 or 6 hours, all in, with getting every last bit of adhesive good off the glass with Rapidtac cleaner.
Kept the truck's doors open with a fan blowing overnight to make sure the moisture was all gone.
Cannot beat the clear glass look.
Dang, that's awesome. I did not fair so well. Mine came off in very small pieces and I had to razor it off the back window. Need to replace my defrost lines.
lilchizler.com
Depending on how badly the defrost tracks were damaged (if at all), you can repair them with conductive paint pen. I use one made by MG Chemical. Put some blue tape down flush with the edges of the track and 1” or so on either side of the break, then paint away. It takes a few tries to get the hang of how the paint flows especially upside down. Sometimes it takes a few coats, especially since the pen tip can scratch the previous coat if you’re not careful. More is better.Even with the steamer, the hatch glass was a PITA. The film wanted to tear along the lengths of several wires.
The Chizler is probably my best tool for encouraging the film to come up. It has a very fine edge but it really strong.
"Lil" Chizler
lilchizler.com
Man this is a project ive been meaning to do since i got my truck. my defrost does all of nothing.Depending on how badly the defrost tracks were damaged (if at all), you can repair them with conductive paint pen. I use one made by MG Chemical. Put some blue tape down flush with the edges of the track and 1” or so on either side of the break, then paint away. It takes a few tries to get the hang of how the paint flows especially upside down. Sometimes it takes a few coats, especially since the pen tip can scratch the previous coat if you’re not careful. More is better.
I think this is the one I got, it’s carbon based. Maybe I got one with nickel in it, can’t remember but anything will work to some extent.
Also check the big 12awg (or whatever size) wire for the defrost lines where it goes through the rubber boot between the body and the hatch. A lot of them break there, so even if your grid is fine, it's not getting power. Took me a long time but everything in my rear hatch works!Man this is a project ive been meaning to do since i got my truck. my defrost does all of nothing.
my grid definitely has cracks in it. I think someone got a little carried away removing window tint at some pointAlso check the big 12awg (or whatever size) wire for the defrost lines where it goes through the rubber hatch between the body and the hatch. A lot of them break there, so even if your grid is fine, it's not getting power. Took me a long time but everything in my rear hatch works!![]()
FWIW, use the steamer between the glass and tint film, not on top of the film like you pictured. Mine lifted off quickly and effortlessly, esp on the rear hatch glass. Only a couple sticky spots leftover.On the '87 60...Finished a project that I started a few years ago....
Worked like a charm. Despite the film wanting to separate into two thin layers and tear. Probably 5 or 6 hours, all in, with getting every last bit of adhesive goo off the glass with Rapidtac.
Tried it that way and couldn't get any sort of momentum. I was heating a square foot or so, then giving it intense steam on the folded edge that I was working. Without the preheat, it simply wasn't coming up.FWIW, use the steamer between the glass and tint film, not on top of the film like you pictured. Mine lifted off quickly and effortlessly, esp on the rear hatch glass. Only a couple sticky spots leftover.
Just get a corner started on the bottom of the glass somewhere and work upwards, let the steam rise under it.
After finishing up the tint removal project, the 60 got to run around on errands in town yesterday.
One of my favorite Toyotas. I love that truck.
She had been riding on some very old Firestone MTs. Now she's sporting a set of Nokian Outpost ATs. Which ride nicely and don't trigger my tinnitus.
