That’s a good idea to repurpose those old running board wires
Thanks! Not sure if I saw it on here or Reddit, but I 100% stole the idea from someone else.
May I share my experience/journey (albeit P043E&F and no humming under console) and fix...When it rains, it pours I guess. Just got done doing calipers, pads, and rotors for my GF’s Xterra. Today my GX is lit up with check engine, VSC TRAC, and VSC OFF.
Scan tool shows P0442: Evaporative Emission Control System Leak Detected (Small Leak), and there’s a weird mechanical humming noise coming from the center console area with the ignition set to on.
Fuel cap is only a year old. So I doubt it’s that. Pretty sure the only way to fix this is paying a shop to do a proper smoke test of the EVAP system.
forum.ih8mud.com
forum.ih8mud.com
Xmas tree.ligjts and codes:
Build - DRANGED's GX470 build/ownership thread
forum.ih8mud.com
Then dealer scan and.finally evap canister swap (surprisingly easy)
forum.ih8mud.com
Good luck![]()
Just did the same tonight. Was only planning on doing one light per side as I had a pair of harbor freight rock lights, but ended up just connecting both to the factory harness on one side, and I'll just buy another pair and do the other side soon. Very happy with the results so far, just have things zip tied for now as it was getting late, but I plan on mounting them in the same fashion you did.Thanks! Not sure if I saw it on here or Reddit, but I 100% stole the idea from someone else.
Here is the unit I purchased on BF.
Joying 2004-2009 Toyota Land Cruiser Prado 9 Inch Android 10.0 Car Stereo Built-In Bluetooth
SKU: JY-TQ158N4G-BShip From: Chinese WarehouseCPU: UIS7862 12nm Dual ARM Cortex-A75 + Six ARM A55Ram: LPDDR4 4GB Rom:EMMC 64GBSupport Bluetooth, WiFi, DVR, OBD2, Back-Up Camerawww.joyingauto.com
Highly recommended and a very straight forward install even for the inexperience like me!
Was it a factory Lexus cap? If not, quite possible it’s the capWhen it rains, it pours I guess. Just got done doing calipers, pads, and rotors for my GF’s Xterra. Today my GX is lit up with check engine, VSC TRAC, and VSC OFF.
Gas cap was just loose. Friend had borrowed the truck the day before. I’m guessing they didn’t tighten it after adding gas. I took it off, tightened it until clicks, and cleared the codes. 150 miles of driving and 1 fill up later, and no codes or lights.Was it a factory Lexus cap? If not, quite possible it’s the cap
Indeed! maybe we'll cross paths one day. I need to get back to Johnson shut-ins and elephant rockNice rig! I thought I had one of the only Missouri GX's on here. I'm on the other side of the state as you (Farmington), although we also have a lot of good backroads and some decent trails over here as well.
source??JDM Prado 120 tails installed
Sweet fix!!!!!Gas cap was just loose. Friend had borrowed the truck the day before. I’m guessing they didn’t tighten it after adding gas. I took it off, tightened it until clicks, and cleared the codes. 150 miles of driving and 1 fill up later, and no codes or lights.
Seen a lot of suggestions for oem caps, but this one from O’Reilly’s has been fine for a year. Will grab an oem one if it happens again. Just thankful it isn’t an actual evap leak. That could have gotten expensive real quick.
Man, I was thanking the universe for that one. Spent those 150 miles on pins and needles, just waiting for that light to come back on.Sweet fix!!!!!
go OEM, not oreiley or even napa....although, in hindsight my codes 9different from yours) ended up being the whole evap canister as my gas caps didn't resolve the issue through time, either one..
I got them on Yahoo Auctions Japan! Yeah they look great, better than I anticipated even.source??
looks good on silver, me likey!!
hows the illumination with double reverse lights Assuming you're keeping GX and have wired the prados. . . ??
Are you able to access the reverse camera at any time in any gear? Or will it only turn on in reverse?Here is the unit I purchased on BF.
Nice to have such a tall garage door! I'm jealous!Little suspension update/upgrade time. Factory suspension was clapped out and this new stuff is oh so nice. Just did this yesterday so it will take some time to settle but I’m happy with the results so far. Have an alignment scheduled for Tuesday and then it’s time to do some more clearance work to get the tires to fit a little better
