My brother finishing up "Daisy"
Soon he will be Driving Miss Daisy!!!Sure.@Pighead I’m about to either tackle this or farm this out for Marge. Could you put a list of parts you picked up for this job and where you sourced them?
They will, of course, check for flatness. I asked them not to shave it more than absolutely necessary. It was shaved once when I built it the first time.@Pighead is the machine shop going to shave the head or was it flat?
new valve seals I’m assuming?
How bout valve guides?
Springs?
Spring keepers?
New freeze plugs?
What specific problem are we trying to fix here, and why are the cheap and common solutions inadequate?Custom valve stem seals ???????? tell us more
nope. My mistake, I must have mis-heard. What he's gonna do is turn down my valve stem bosses to fit the stems that fit the chevy valves. sorry.Custom valve stem seals ???????? tell us more
No specific problem other than routine maintenance. I figger an engine rebuild every 500K or so and a valve job every 250K or thereabouts. I've been putting it off long enough.What specific problem are we trying to fix here, and why are the cheap and common solutions inadequate?
A set of valve stem seals, which are good for 200k as long as you don't overheat, are available at just about any machine shop for $20 or so. They're working just fine in millions of engines right now...
What gives?
It looks like the Intake valves and the earlier Exhaust valves are available. I get discontinued on the later Exhaust valves. I didn't do an exhaustive search though.Are OEM Toyota valves still available? My searches are turning up a big fat no but you guys always seem to have sources I’m not looking at.
| 13711 | VALVE, INTAKE | ||
| 13711-60021 | 6 | ||
| 13711A | SEAL OR RING, O(FOR VALVE STEM OIL) | ||
| 90913-02017 | (10/1970 - 07/1976) | 12 | |
| 90913-02030 | (08/1976 - 09/1978) | 12 | |
| 13711B | SPRING, COMPRESSION(FOR INNER) | ||
| 90501-45342 | 12 | ||
| 13715 | VALVE, EXHAUST | ||
| 13715-60032 | (06/1973 - 07/1976) | 6 | |
| 13715-61010 | (08/1976 - 06/1980) |
Which one are you going to use? What are we looking at in the 2 pics above?I learned the hard way I had head Rebuilt purchased valve seals for Toyota, Shop says they won’t work, So we put Chevy LS seals in it look almost the same as what came off head but no rubber on bottom they did not work every time I started it it smoked, Georg at Valley Hybrids found me the right seals, The short seal is what came with the the head gasket kit did not work for me, Please post pics of the machine work on the top of head for the seal ,
