Where in the U.S. will it end up?refreshing this fzj75 before it heads to usa!
View attachment 3319255View attachment 3319256View attachment 3319257
somewhere in the southWhere in the U.S. will it end up?![]()
P.M. sentsomewhere in the south
did you replace the knuckle housings too?Finally got my knuckles rebuilt. New rotors, calipers, pads, brake lines, and installed manual hubs.
Refilled the front diff with MT-90 from RedLine.
negative. I ended up being able to get most of the cemented on Omani dust/dirt/sand off with a wire wheel. I had purchased an entirely new left side knuckle housing, but ended up not using it.did you replace the knuckle housings too?
I thought you converted from power locking hubs to manual? What’d you do with the hole in the housing where the cable on the backside of the spindle goes?negative. I ended up being able to get most of the cemented on Omani dust/dirt/sand off with a wire wheel. I had purchased an entirely new left side knuckle housing, but ended up not using it.
I did not have power locking hubs. I had the non selectable hubs similar to a 100 series.I thought you converted from power locking hubs to manual? What’d you do with the hole in the housing where the cable on the backside of the spindle goes?
Where is your neck of the woods?Engine oil has become expensive around here. Manufacturing shortages, I was told.
My mechanic also told me that 71 Series are becoming "classic cars" (whatever that means) in my neck of the woods.
Juan
Dobinsons suspension going in. Got the front done, doing the rear tomorrow. Visual difference of Toyota vs the Dobinsons IMS shocks.
Might be premature to tell but my butt says that the IMS and spring combo make for a great upgrade over a newish stock suspension.Those IMS sound like they are supposed to be fantastic. Very tempting.
Lift is complete. Tie rod ends and an alignment when I get back from vacation.
Front springs: HJ75-8L-F
Front shocks: IMS59-50705
Rear springs: HJ75-6+2-R
Rear shocks: IMS45-60115
Damper: SD59-824
Dobinsons? If so yes.You used the "D" brand suspension upgrade?
Did you do it yourself?
Wondering how long it took you?
