My ’72 FJ-40 Water Temp Gauge does not work. The gauge is functional. The problem appears to be with the sending unit. I have tried both aftermarket and Toyota senders. On my gauge at rest, the needle is all the way to the right (Hot). As heat is applied to the sender, the gauge needle deflects to the left, or Cold. The warmer the sender becomes, the farther left the gauge needle moves. In other words, the warmer the water becomes, the colder the gauge reads. Without being connected, the gauge measures about 46 ohms across the terminals. Without being connected, the sender is open with no resistance. As the sender warms, it begins showing resistance, reading anywhere from about 130 to 190 ohms. It appears that at rest I need a sender that is in a normally closed position (dead short) in order for my gauge to function properly.
There are many pictures on Mud of instrument clusters, and at rest, some show the water temp needle all the way to the right and some show it to the left. I suspect there are different senders depending on what Toyota changed from year to year.
Thanks to Bj40green! He has a great posting on Mud which is very informative.
Can anyone please Help?
