Water pump how to
Maine
Overheated last night, leaking pretty bad at the water pump. Thinking of ordering one and tackling it myself, that would be my biggest job yet. Reading the FSM, doesn't seem too bad. I've searched but can't find a Mud version of a how to for this though. Anybody have one? Or pictures, videos?
u can tackle that without the fsm, pull belts, fan and pulley and the bolts to mount it an waallla!
ur out east so pm beno for ur toyota factory parts as he is east of the big river somewhere and save some money as a mud member!
may want to go ahead and order drive belts, a new t-stat, hoses and the two round rubber gaskets for whatever the vertical water pipe is called, ur draining the system down anyway so might as well get a few pm items checked off too!
oh, and definately pick up a couple gallons of toyota red from ur local dealer an put in new coolant
(they cant ship coolant via ups or fedex locally, truck freight only)
Mostly agree, but if running green coolant, keep it green or flush, flush, double flush if switching to red. Not opening a can of worms here, but I run green as it is available anywhere if needed.
quick advise - tonight check on those 4x fan clutch bolts (13mm)....
if they come off easy great - because tis not uncommon for those suckers to be "fused" onto the studs -
they are uncommonly soft too - so any slippage and they are stripped / rounded - I had to basically chisel them off by hook / crook.
as they are the starting point - the whole project could get bogged down if those bolts don't come off or get supremely stripped.
so before you go "whole hog" and start draining coolant -
but (come to think of it) I guess since you are replaced the water pump - it should come with new studs - so any issues thau do arise you could just cut off the old ones...
agree too with above - since you are "breaking" the water system - do it all - fhh, phh, water heater, valve, tstat, and h20 pump.
bf
My two suggestions are:
1) buy the Aisin water pump from Amazon.com, its much cheaper and its the same thing you will get from any Toyota dealership.
2) when you go to take the bolts off of the water pump, use a 6 point wrench rather than 12 point. You will greatly reduce the risk of rounding the bolt heads.
3) super secret bonus tip : acetone and automatic transmission fluid mixed 50/50 in a spray bottle will give you the best rusted bolt penetrating lubricant you can get.
This isn't too bad, just lots of little steps and "while your in there"s that accumulate. I think the only odd tool you need is the fan tool so it doesn't spin while you loosen the bolts. I got the AISIN water pump off of Amazon too, I have had zero issues with it. However, if I would do it again, I would have used that pump with the OEM gasket. The one it comes with is this little paper thin POS rubber. I put a thin layer of RTV on it, but it still strikes me as sketchy. One of the vendors might be able to confirm the OEM one is thicker/paper and more forgiving.
Make sure you spend the time to get all your old gasket off, and make a nice clean surface when you put the new one on. Not a bad time to replace your hoses either. I think there are ~4, as soon as I finished (I installed a new radiator too) coolant started leaking out of my truck. I nearly lost my mind, but it turned out the lower rad hose was toast....big relief it wasn't the pump.
X2 on #3 My brother and I used to run a small shop and this little trade secret was passed to me by an old timer who came from back east. It works really well, better than Kroil....WAY BETTER that Zep.
The pump is a:banana::banana: job at the most, you're more than capable if you have 10 brain cells 8 fingers ( at least one thumb included) and a somewhat decent tool set and patience. I've personally witnessed a pump replaced with borrowed vice grips and a lot of swearing from someone with 8 and 1/2 fingers lol . As for paper and metal gaskets, I replaced mine with a lifetime warranty GMB and it had a paper gasket (1fz-fe). Just make sure you take your time and have the proper tools and all the pieces to the puzzle before you begin. Make a list and check it a few times to make sure you cant think of anything else you might need before starting the job. While you have the system open, you might as well replace the upper and lower hoses, flush the heater core or add a flush kit, and replace the thermostat. Get it all done in a couple of hours.
Good luck to you. and as always...Post pictures for those of us who don't like to read:)
Absolutely tackle this job. Loosen the fan bolts before you take off the belts. This is a half beer job.
bf
Thanks for this tip :)
If there is any issue at all with the nuts on the studs don't waste your time, just buzz them off with a sawzall as the new pump will have studs.
Sawzall worked perfectly!
I probably wouldn't have jumped right into chopping them off without reading this.
Thanks!
You need to throw those 13mm nuts in the trash and get 12's. If you have 13's.
Mine were 12s but I didn’t have a 6-point wrench so I rounded them pretty quick… pretty soft metal.
Sawzall took 3 of 4 off no prob and the 4th just took another try.
This is a 1-2 :banana: job, pretty easy and a great way to learn about your truck.
While you are in there, go ahead and replace the tstat and gasket too. And perform a proper flush- http://www.ford-trucks.com/forums/9...kflush-procedure-and-coolant-information.html
Read that above, it's designed for a Ford but the principle is the same. I did this on mine and it's the only way to ensure that all your old coolant is actually removed.
Your choice on red vs green. You may want to replace your belts too, or put a new seal in your PS pump if it is leaking, another couple of "while I am in theres"
If you have a 93-94, be careful with the little nipple on the top of the rad. I broke mine while doing it and it cost me a ra :( , (read $$$)
Report back if you have questions/problems, there are many of us who can assist you if you run into a problem.
If you are going to do the t-stat, on top of the t-stat gasket (looks like an oring with a groove on the ID to fit around the OD of the tstat) get the rectangular gasket that goes between the tstat housing and water pump housing. 16119-66020, called the thermostat guide housing. You'll loosen three of these 4 bolts to get the tstat out, and it is possible to disturb that gasket and cause a leak there.. which requires tearing the tstat back apart to fix properly. If you already have the tstat out, this gasket is super easy to get to, and is not expensive.
I installed one of the amazon WPT023 aisin pumps literally a few days ago.. it came with a high quality rubber-coated-stainless gasket.
  • Like
Reactions: rrt
Yesterday I went to Canadian Tire (proximity) and I got a Preston flush kit.
Also picked up a few jugs of Toyota Red and bought 24l of distilled water so I can do a few fills and flushes.
The previous owner was using green coolant but I’m planning on switching to red (after running just distilled water and flushing a few times)
After reading the above I’m ordering this gasket and replacing so things are probably on hold until Monday.
I completed this a few days later. Waterpump, Thermostat, gastkets, and new OEM belts while I was at it.
Currently I have it filled with distilled water and then I'm going to drain, prestone chemical flush, fill with water again, dain and finally fill with Toyota red 40/60 distilled water.
I'm hoping this will reduce the sludge in the coolant. So far it seems to be much better after a drain and fill w/ distilled water but still a little bit of sludge when I pull of the rad cap.
The PO had used green and possibly mixed it with red or switched without a proper drain/flush. I had just been refilling with green and had it in mind to switch when the opportunity presented itself, which it did on the Coquihala Highway :-)
Thanks again to those who provided tips above! I have done lots of wrenching in the past but it's been a while and this stie is a huge help.
Ryan
I took my fan off and was able to wiggle it out without removing the shroud. Once the fan is out the rest is cake. Just do it over a drain pan and have some old towels handy.
Good luck.
