Thanx for the info, guys
I ordered up the Slee kit on Tuesday and it showed up this morning
Since I already had the FJ tray and all the necessary hardware, I went ahead and installed it.
The tray needed just a slight trim to clear the fan shroud and I used the included sticky sponge to seal it...
I test fitted bottle with the brackets installed as per Slee's intructions, but before I could tighted the bolts down, I could already tell the bottle was too close to the wire harness on the firewall and the cruise control cable was starting to bend
So I took it apart and reinstalled the bottle and supplied spacer behind the bracket and everything fit nicely
There's a safe gap between the rear harness and diag connector and the cruiser control cable is free of stress (doesn't even touch)
On a sidenote, going by the pix previously posted in other threads, it looks as though Slee changed the angle of the bracket that bolts to the air cleaner as mine had a solid 90* bend on the end that bolts up to the bottle
Mine:
Jomo's:
Didn't like the wire that came with the kit, so I'm gunna install some leftover 2-wire tin shielded conduit cable tomorrow
