It's bad enlightening that after a few miles up in the mountains it's leaking onto the heat shield and when you shut it down smoke comes from under the hood.
I am guessing that I will have some serious cleaning to do. My plan is to spray down with simple green and let it sit for a few hours. Then spray again after work and hit it with a garden hose or pressure washer. I am a bit worried to blast with and serious pressure I am thinking he wide angle pattern should work. He other alternative is rags and elbow grease which will take take days I fear.
If you have basic hand tools, this job is perfectly achievable .. Just set aside 2-3 hrs max(if your not a experienced gear monkey) and your good. Just take the air cleaner tube off, 4 bolts on throttle body (set it aside) then the valve cover gaskets.. You might as well replace the 6 spark plug grommets/seals and the pvc valve and rubber grommet..
Nope.. The cables are pretty flexible.. I wouldn't bind them all up, but throttle body can easily be put to the side without disconnecting the cables.Is it really that easy ?!?! I thought I had to disconnect all the cables to the TB.
