Unobtainium
Racer
I need this gasket that goes on the bittom of a 76 air cleaner. I also need the top cover gasket for the stock air cleaner thats bigger than the one shown in the picture. I can send this gasket to you as a master. Its still in fair condition but would like to have a new one. Both in er gaskets for the air cleaner are not available. The only gasket that beno can get is the one between the carb and stock air cleaner. Pm me if you are interested and i will ship this one in the pic to you.
I'm pretty back-logged with projects at the moment, but please save that piece as I might revisit it at some point. Thanks!
I had the same issue with my '77 when I sourced a used air cleaner complete since mine had a junk Rochester on it from the PO . Had to make a new gasket out of different material that's just slightly thicker - needless to say the lid goes on pretty tightly but it does seal well ...lol .
For that wiper switch cover , I'd really consider some sort of silicon rubber to handle the elements and the heat from the motor in the summer.
Sarge
Here are some photos of the '79-'84 plug. Now that you say it's discontinued I have to carry it in the store :mad:
View attachment 1290557 View attachment 1290558
I actually stock those male oval 6 pin connectors/terminals/seals though the connector bodies are green like the original Toyota plugs. However it's the FEMALE connectors that mates to these male tail light connectors that I have not been able to locate! I DO have the female terminals. It makes building OEM harness for 76 and later a bit difficult. I have to use aftermarket connectors and then have the customer send me their tail lights so I can re-wire them to match...
With your contacts and buying power you might be able to locate the female versions. (Hint... hint... :cool:) I would buy them from you!
Here is a pic of the female connectors...
Yes Mark, that looks like a connector for OEM taillight units................
Cruiser porn.
So is the first iteration for the 79+ trucks?
No, this floor mat is for '73 to '78. As covered earlier in the thread, the TOYOTA logo in the heel pad area is done away with due to copyright reasons, so the heel pads resemble a late model design.
I'm not totally sure if the mat works for earlier years. This post talks about the differences in the floors, but someone with the early trucks will need to weigh in on whether it's enough of a difference to pose fitment issues for the floor mat.
The '79+ mat is quite different for sure. That'll be another project for another day.
