Turn signal issues...
Here. Now.
This is the first significant electrical problem I've had with this rig, maybe I'm lucky...
Right side turn signal no blinkie, Left side works fine: no light at rear right; front light on, no blink; brake lights work, emergency flasher works (i think); lights come on with headlight switch (didn't check turns with headlight switch on).
I've checked for bad bulbs, checked the sockets (one was loose, but no change), fiddled around with the grounds but didnt go behind the cargo panel yet...
Any ideas where I can narrow the search? turn signal switch? The flasher?
(IH8Electrical)
:doh: now you have done it.... never say that
but anyway, I would check the turn signal flasher. pretty cheap part to pull out and replace with a new one from Napa or whatever. I have seen bad bulbs do this, but it seems you have checked that.
Did I just jinx myself? :rolleyes:
My question would be, would the flasher work with a left-turn, but not a right?
I read some of your threads looking for solutions...
I would say that if the left side signals work fine, then your flasher is OK. Do you hear it clicking even though the lights aren't flashing? The headlights have nada to do with it. So I think it be somewhere between your turn signal switch and the flasher switch, or their connections, if they are like my truck and connected (I bet they are).
If the brake lights are working then at least your rear ground is probably good.
First, I would find out for sure if the emergency flashers are working all around. Next, I would trace the harness back from each light and see that the connections are good, and use a test light to see if signal is getting through at each connection. Then, you get to dig into the dash.:D.
If the right side lights light up but don't blink, then that side isn't sinking enough current (eg aren't burning bright enough). Could be a bad bulb, wrong bulb or a bad connection anywhere between the switch and either of the grounds (F/R).
An electronic flasher would make they blink regardless, so it wold be a band aid until the problem gets worse.
Ground
The ground for the bulbs in the front turn signals pass through two places where you count on metal-to-metal contact to make ground. One is the reflector to the housing, the second is where the housing bolts to the fender.
I took one of mine apart, cleaned it and sanded the contact areas, put it back together, and bzzzzzzt. I had to do it again, more carefully and thoroughly before I got it to work. I also had to tighten the mounting bolt more than I wanted to.
The blinkers f+r on that side did not work without proper ground. I doubt the flashers worked either but I didn't test them.
nuclearlemon said:
i'll second checking your grounds on that one.
Yup. I just checked: Rear lights work on headlight/parking circuit. No right rear brake light or turn signal. With right turn indicator on, front light is on with no blinking, no rear rights blinking. No right rear emergency flasher. The flasher makes noise when I signal a right turn...
I'll check my grounds this weekend, I really didn't want to pull out the meter and test light...
:mad:
I think the piggie is just mad my wife didn't want to take it camping last weekend (I did anyway...:D )
I had the same problem with my T-100 turned out to be the U-haul wiring harness that was all screwed up. I un-wired all of it and problem solved...that is if you have a towin wireing harness:D good luck
I have the same problem. my turn signles have not worked in a long time. Now the head lights and parking lights don't go on. I will work the things mentioned above. good thread, good timing
...I got a few rusty grounds to check back there... This just came up in the last week or so...
surf,
get out the meter and listen to idave and pinhead...it took me hours to finally resolve the same issues you are having.....but thanks to those guys all works well now....this weekend i am going to tackle the parasitic drain on the battery...hopefully with the help of idave and pinhead!
good luck
osagecruiser
Have you done any wiring mods/fixes/repairs? Besides the normal grounding issues thid could also be caused by improper wiring which I have seen. It took me a good day to figure out what they had done.
nuclearlemon said:
take it camping again followed by at least mild fourwheeling and call me on monday.;)
I like that prescription! Not till next weekend, though...
The wiring is the one thing on this rig that wasn't F'ed up by the PO. It's pretty intact, except the cooling fan, which I completely re-did earlier this year. There's some coastal California rust issues, and I think there's just a ground that finally dissolved...
Any wiring I've added is through an aux. fuse block, I've seen what can happen otherwise...
You mentioned the rear right doesn't blink when the hazard switch is pulled. Does the front right blink with the hazard?
Does the dash indicator light blink with the hazard?
Does the dash indicator light on the right stay on steady with the turn signal switched to the right, like you said the front right turn signal does?
Just trying to sort out whether you have one or two problems on the right side. :D
check the current flow on your battery, disconnect the negative battery terminal and hook up a test light in series from the battery post to the terminal. If indeed it is draining you will see the test light come on. start disconnecting/connecting it until you see a change in you test light. My guess would the voltage reg. or a switch that has malfunctioned. Sorry for the high jack.
osagecruiser said:
oh man...good luck...i think my electrical problem moved to your truck....i had the same issues...finally got them worked out....no i have a battery drain i am trying to find....good luck
osagecruiser
