That part about not having the correct bulbs is true. The previous owner did this to me......the turn signal would not work unless the cruiser's engine was on. was I doubt this is your problem since you owned it for a while.
Almost sounds like the rear light assy. is causing your problem. Swap the two rears and see the problem moves. Also check the flasher. In the past most of my problems as far turn signals, I have had dirty/rusty connections, wrong bulb and a bad ground at the fuse holder. Also reseating connections will do the trick.
surfpig said:Yup. I just checked: Rear lights work on headlight/parking circuit. No right rear brake light or turn signal. With right turn indicator on, front light is on with no blinking, no rear rights blinking. No right rear emergency flasher. The flasher makes noise when I signal a right turn...
I'll check my grounds this weekend, I really didn't want to pull out the meter and test light...
I think the piggie is just mad my wife didn't want to take it camping last weekend (I did anyway...)
