TRD Supercharger?
S/C kit also includes a ringed fan of questionable efficiency. Mack
Christo
I don't doubt you on HP but it is a great improvement.
I think if one only looks at the stock gauges it is pretty good as invisible power
OCD crew need to be more anal. :)
I have 2 different setups on the IC and other works better in heat but I still pull for a good bit before it gets to AC cutout. Post IC temp stays about the same as IAT.
No problems at all w AC is off
I have a smaller pulley for more boost but its a bit more involved to take the pulley off than I tought. Will do that w I have time
If you need to run with the AC off then there is a problem.
i find it hard to beleive that people would think of this as a hp add on you have obviously never driven one with this .one would be better off either stroker sbc.or deisel convert for any noticeable difference for the dollars involed.although my preference between the turbo and supercharger would be the sc only because of the bottom end pull right through to red line,but dont expect the low oil pressure issues to get better either,when your useing the motor for more than it wants to.i personally never had heat issues with mine ,mind you the truck was factory and only a couple years old,but had the oil pressure issues.one can only imagine haveing to compound the heat issues with this.
Oh yeah, I forgot about the ringed fan. I edited my previous post.
By the way, I have never had any cooling issues as a result of the ringed fan. I pulled a several thousand pound trailer across the country with my S'charged 80 too.
Although, on the trail I do open my hood at every stop to dissipate heat but my coolant temps are normally 180-195F on the trail & 165 - 185F on the road. Sometimes, at higher elevations and hot ambient temperatures I may get to 200F as measured by a ScanGauge II ocassionally under load at a slow, steep crawl in 4LO.
Phil,
If AC is needed, I use it.
I meant that there is no problem w I don't use AC (winter for example)
On hot summer days, with a long grade and elevation (like 9 Mile Rd up to Kennedy Meadows) it would hit AC cutoff.
with everything I've done, it performs better than when the truck was stock.
The IC does keep intake temps down. I don't know what the effect is overall-
for example,
If I run 130F IAT, and my post-IC temp is 105F - that means the IC is doing some significant cooling.
On hard pulls, it can run even- 130/130 for example- which means the IC is cooling the charge a lot.
So the IC does work well, I believe. How that correlates to actual engine performance, I'm not sure. The IC helps to keep boosted IAT at stock or below stock levels.
My aux rad significantly helps cooling temps. I have not had issue with hitting AC cutoff since I did it and it will cool down immediately after hard pulls.
I'm happy with my system and it has become an interesting process.
One thing to note is the location- Ali (New Mexico) ran 190's but in LA, he noticed it normal to run 203 zone.
When you drive mountain grades that have signs posted *turn off AC - overheat area* *emergency overheat water pulloff ahead*
I don't think it would be surprising to run hot on those grades.
As Christo alluded to, it's maybe important to mention that if I were just using my stock temp gauge, at this point, would say "it never gets hot or in the red zone but it's gotten warm sometimes".
S CarolinaFZJ80,
I have similar IAT numbers as you but sometimes they can get higher. I have teh stock intake.
I have thought of putting my snorkel in but it really makes my bookshelf...:hillbilly:
I don't know why one 80 runs hotter than another but I've seen the inconsistency amongst my friends trucks.
It's strange considering we all have the same maint done. Something more to chat about over the campfire I guess...
Hope everyone is having a nice holiday!
i find it hard to beleive that people would think of this as a hp add on you have obviously never driven one with this .one would be better off either stroker sbc.or deisel convert for any noticeable difference for the dollars involed...
There are more than a couple of guys on here who are happy with the hp add on, and a lot of them have been driving them day after day. Not saying it is the best route, but it is certainly a legitimate option for some more HP.
For a one banana guy a TRD SC adds some power and can be done in a day or so for ~$3500. For a one banana guy a SBC will cost maybe $10k+ (educated guess), to have done by a shop that hopefully knows what they are doing. For a one banana guy, a diesel conversion will cost $20-25K (i.e. Profits Cruisers) from a shop that knows what they are doing. Those are not really comparable for the dollars involved, IMHO.
Merry Christmas!:)
well sorry for my bad luck with the oil issues i had with my first lexus .oil pump then bebs then bad oil presure again,i ended up tradeing it straight accross for a new passat wagon deisel,from the dealer. only to find out later that these things have bad sending units and gauges.but i will say i did not have heat issues here on the west coast.i thought the sc was a 5grand add on.plus i thought a sbc was about the same plus a bit.i found not a huge power difference between the two gas pots i had,both 97 s one full load lexus with the factory sc and one 40 th full load.then i got into the hdt s for under 10 grand loaded and the power diff. is quit noticable. i just sold two trucks that i had totalled but both were complete locked loaded one deisel jdm one 40 th with real low km for 5300 hundred.a deal yes but these are out there to be had.does anyone run a propane injection system .i would think that these motors should be able to handle this add on also in moderation of coarse.but then again im not that knowledgable and kind of new to the cruiser thing.wishing the best to everyone and their trucks
There is a used one in the mud classifieds for 3 grand.
Gone Forever Johnson.
I was told that TRD originally made the tooling to produce the supercharger it took them about a year to sell all of that first run. They are not interested in developing new tooling for such a product, because they believe it will have soft demand.
Direct fit from Toyota. Some wiring modifications.
PTR29-60097
LIST: $3750 MUD: $3299
Currently, there are none available in the US, 3 on back order. I do not know if TRD will be making another production run of these units.
Are you a supplier? I’d like to order one in the next couple of months if possible. Was looking at Turbo, but I’m in CA.
***Need CARB cert***
And I don’t want crazy boost. Just enough to get up them grades and up a mountain with a bit more push.
Any help is appreciated.
You quoted an 8-year-old post. Kits have been gone for a very long time.
