TRD Supercharger?
Direct fit from Toyota. Some wiring modifications.
PTR29-60097
LIST: $3750 MUD: $3299
Currently, there are none available in the US, 3 on back order. I do not know if TRD will be making another production run of these units.
What TRD supercharger is everyone on here putting on their 80? Is it a direct fit or do you have to fab it?
The TRD kit for the FZJ80 is a direct fit kit. Very little actual fab work involved. What gets most of us is the 'while you're in there' projects that add up in a real big hurry.
You'll want to look up some of the installation threads. The wiring harness extension and the crank bolt are two to pay attention to.
Cruiserdan at American Toyota would be able to sell you the kit itself as well as any other 'while you're in there' parts to change out.
When I put mine in I tore it down to the head gasket and rebuilt it back up from there. If I classified a part as a 'wear out part', I replaced it. So, new water pump, fan clutch, fuel filter, hoses, belts, radiator, thermostat, plugs (cooler MR2 type), EGR valves, etc... I had the injectors cleaned and flow checked (they were good) and put in new seals for them. I put in the non-normal V6 fan and trimmed the fan shroud to match, added an OEM pusher fan to the front, pre-wired for aux headlights, added switches and relays, modified the water bottle to fit behind the air filter can (dual batteries had already moved it once), put in a washable air filter... It was a long list.
Be sure to be sitting down when you get the price for the SC kit itself - then you might want to lay down before you hear the combined price with all the 'while you're in there' parts that may make sense for you to get at the same time. There is a good chance you paid less for the whole truck.
PTR29-60097
Wow - that was FAST!
the trd one isn't all that anyway and it was essentially a retooled eaton m90 i believe. might as well build a kit custom and get some real power out of it....If you are gonna spend 4k+ ....You can go turbo for a quarter of that cost if you know what you are doing and research it.
You can buy an eaton m90 and probably have someone build you the bracket work for under 2500
Not for the '91 or '92 3FE...
Also not recommended for the '93 or '94 Cruisers due to the ECU.... BUT can be made to work for those that are careful or hard headed, someone here is running one in a pre '95 but has extras added to make it work.
$3-4k is also in V8 swap territory running N/A, but that is another thread.
They don't make them in Japan either.
Yep, mine is a 94. I was weighing the cost difference between charger or chevy 8 and was curious about the extent of the work involved. So the TRD charger doesnt really give 3k worth of super to the truck? I have seen threads with people speaking of crazy hp out of the stocker with mods of coarse is this really possible within a reasonable cost? I want to run 37" tires and still have plenty of power to run highway speeds and play but no crazy low gearing to rev the truck to the moon.
The TRD supercharger will give some pep to your 80. It's definetly not a V8 but gives it a good boost (up to 6 psi with stock pulley). Merging on to the highway and steep grades are no longer an issue.
I got mine used and doubt I would drop $3,400 for a new one. If you have some serious fab skills & tons of time, I'd say do a V8 swap.
I am running the TRD super charger and it is fantastic! I would rather go for the factory spec'd TRD supercharger than a custom turbo any day of the week...I'll take the factory warranty from Toyota.
Now, a custom turbo would be great...but, the reliability of the 80 is what hooked me on an 80 in the first place...so, why compromise it with a custom turbo or supercharger setup...when you can go with a factory spec'd unit.
- Mark
$3400+ 2days = 100hp added. That's cheap power and it transforms the truck.
I wish I had done the SC much sooner but really glad I did not miss out.
Fitting a non-specific m90 will take 100x more time & effort, will not be much if any cheaper and not yield the same result.
But if it's so cheap and easy, go for it. It would be a great alternative since it looks like the TRD is unavailable.
Turbo is great but is not cheap, easy or as foolproof as the TRD SC.
If you like to sip your latte as you drive, nothing wrong with a stock motor either...
If you can put a turbo on a 80 for $1k, I would like to see it and I am sure a lot of other people would love to buy it.
Also, I would love to see a custom supercharger done for the price of the TRD unit.
To the other poster that commented on factory warrantee, you should check your docs of the supercharger. There is a warrantee from TRD on the blower and kit in terms of defect of materials, but I do not believe it covers your truck. However there would no 80's still under factory warrantee, so it doesn't really matter. These days you bolt on your $'s and take your chances.
Firstoy, the 100hp is greatly exaggerated. Sorry :D Maybe theoretically at the flywheel, but not at the wheels in reality. However as you said, bolt on, easy of use. Only issue is underhood temps that most if not all people struggle with. But then those are normally the people that are OCD. I have seen quite a few trucks where people that are not cruiser maniacs had the dealer bolt it on and then drive the piss out of the truck. They normally go for a pretty long time.
PS, what is your long term impression of the intercooler kit you guys did. Is it enough capacity to keep the charge cooled for long sustained pulls?
I had considered going the SC route but from what I hear the 100hp is not there in the end, it raises the underhood temps and opens up other cooling problems which for me in Arizona is not desirable. I am leaning towards a rebuild bored which from what I have seen are very close to SC HP numbers in the end with no cooling problems.
Christo
I don't doubt you on HP but it is a great improvement.
I think if one only looks at the stock gauges it is pretty good as invisible power
OCD crew need to be more anal. :)
I have 2 different setups on the IC and other works better in heat but I still pull for a good bit before it gets to AC cutout. Post IC temp stays about the same as IAT.
No problems at all w AC is off
I have a smaller pulley for more boost but its a bit more involved to take the pulley off than I tought. Will do that w I have time
anyone with Dyno info about the TRD SC gains on 80 Cruisers . ? all of you guys running SC running also pigybacks and 7 injector .?
I was wondering what all you get with the TRD kit? I know you get the charger and install stuff but what is done to the ECU to compensate for the extra fuel and timing retard needed under boost?
I have to say nothing looks as clean as a part made for a truck at the factory or factory licensed.
As far as I recall, you get the Supercharger, super charger mount and hardware, metal ducting & 3" hose, a cast plenum that bolts to the throttle body, throttle body gasket, new crank pulley, crank bolt & belt, stainless water pipe & gasket, stainless vacuum tube, various little fittings and fasteners, the belt routing and CARB legal underhood stickers, instructions and a ringed fan to replace the stock fan.
I probably missed something but I recall seeing a post on here with the instructions.
