I’m in the same boat. Using a hacked up tunnel.
Nope. Plan is to use the same mounting hole pattern but raise the portion over the trans. It looks like there’s plenty of room. I’ll just need to do some reforming of the tunnel where it meets the firewall portion of the flange. It works well in my mind so far….So you are going to forgo all the original mounting holes in the firewall and drill a new set 1.5” higher?
Hopefully they can pick it up anyway or print when they get there? We will see.Oh BTW, I don’t think FedEx will be able to scan the label you sent me.![]()
Awesome!! Excellent work. Getting closer.The 4 speed is in! It took way longer than it should’ve; kept bumping the release fork and bearing out of the way, etc.. Installed using a hoist through the trans hole but was by myself, using my foot to try and pump it. 92 degrees outside and 102 inside my metal pole shop doesn’t help either. But it’s in! Off to work but next 2 days when I find time will be hooking up and modifying any linkages, install drivelines and fuel tank back in. Hoping *HOPING* to test drive on Tuesday. View attachment 3074425
Real cruiser community effort here.
I know there are still a couple more things to figure out to make a full install (hump mod and linkages) and @Skreddy is on it.
This has been such a fun and crazy project. I can't wait to put it in my rig as well. @Skreddy has been phenomenal in getting it to this test point. Figuring out the tweaks that need to me made when using this adapter. @Bullzi and I spend way too many hours going back and forth to make the adapter as good as it can possibly be. He really hit it out of the park 3D modeling the adapter to speed up development. @TheNeek and @blbuck12 both did some 3D printing of adapter prototypes as well! @EWheeler and @DomSmith have been the best motivators to me to keep this moving. And a big thanks to @65swb45 for being crazy enough to dream this up and to make the initial prototype we built on.Real cruiser community effort here.
Dom and allBen-
What do you think the best possible options are for the shift arm modification?
Harley piece that you used?
Modify existing piece?
Create a new part?
Any insight on what needs to be done vs the stock piece as it is?
Dom
Definitely think patience is the ruler of the day and the greater success will be a larger number of folks being able to use the adapter which may also help reduce production costs?
Really I was looking for any info on what needs to be done to the shift lever. I must have missed that part.
