- Thread starter
- #41
Awesome, that is what I needed to know, I know on the cummins pumps that if you dont have pressure to them, they will burn up fast, I am learning
Glad to hear it! (and I see you're on the hunt for the 2LT-E manifold/turbo setup...)
Rosco is correct in that you don't need a pump aside from the engine driven IP. You do need an external fuel filter, with a priming pump. The US spec Toyota diesels have one (you might be able to find one in a junkyard), or you could use a Racor.
The 3L should have glow plugs, and be 12V (it's JDM--the engine you are buying?)
Friday eh? That's quick!
Dan
Yes,the glow plug is grounded to the block. A single plastic coated busbar(metal strap) supplies power to the glow plugs.
The plastic cap on top is an insulator in case anything falls on them.
You can see the pastic caps and busbar on my 1HZ .It has "steps" in it to clear the head bolts and I think it may be made of copper. It has plastic coating,except where it touches the glow plug
Well thanks to your advice about the busbar rosco, I energized it, energized the fuel cutoff switch, and then energized the starter solenoid, and it cranked over a few times.....then fired right up!, it sounds great!, ..
the alternators that I am used to using in my setups are GM "1 wire" alternators, but I cant do that with this one, as it has the built in vacuum pump for the brake master cylinder, so this could be interesting! ... But that will be later on I guess..
Awesome. Glad to hear you've got the motor in your hands and at least clattering around. They really are simple that way.
FWIW: I very well may have the faux-lux in the Denver area early next month (like June 7 and 9) if you wanted to look at the turbo setup, and alternator wiring (it's not hard).
I'm not 100% going to drive up for that trip, but I am sure thinking about it...I'll keep you posted.
Dan
The comments about the turbo not being much use when slow wheeling are spot on - you're never revving the engine enough for the turbo to be of any use.
Good luck with your build - it sounds interesting
so..ummm.. contact them and tell them to send the right bellhousing over...
it is their screw up...
