Nothing to add to forward this bit (over my head), but if you want a Turbo setup from a toast 2LTE, give me a shout.
Joel.
Joel.
Joel.
Joel.
well that attitude might work to your advantage, cause the more I have look at it, the less it's worth to me.
Wow, that was fast.
If I had a 3L, I'd be all over it.
Dan
I found a JDM 3L with 40-50k miles on it, with flywheel, the front accessories, and bellhousing, is $2900(shipped) a good price? it is more than I expected, anybody know a good source for low mileage JDM engines?
It's a touch high, but with the bellhousing, it's probably worth it. Which bellhousing is it? To the R series, or to the W/G series?
And it includes the starter right? A reman 2.0Kw starter from Toyota runs more than $300.
Dan
I dont know if anyone said this, but use landcruiser running gear.
Who is selling this engine?
Maybe a dumb question but I dont know a ton about Toyota diesels, would a 3L have a built in mechanical fuel pump(to pull fuel from the tank), or does it require an inline fuel pump?, if so what is a good pressure to have at the injection pump? I am used to cummins engines that require a lift pump. Also I would assume they have glow plugs?, or no? Were most 3L's a 12 volt system?
I am ordering up the 3L tomorrow! Also wonder where I could get some info on underhood wiring harneses on these engines..
