Third Member Swap?
Chesapeake, VA
Website
theshealys.com
1977 FJ40 stock.
Ok i'm not very mechanical but I feel I am learning. I have a known drive train problem when I bought the rig. From what I can tell a lot of backlash. I installed an aussie locker a few weeks ago in the rear and discoverd the pinion seal leak coming out of the drive shaft side of my 3rd member. I went underneath the vehicle yesterday and found a lot of play in the pinion :doh: and a lot of backlash. I'm thinking the pinion bearings are shot as well as the seal. The front had no play in it. So the real question is:
1. Can I swap 3rd members from front to back? and are they exactly the same?
I'm looking at my haynes manual and it looks more complex in the front axle to take of the 3rd. I guess i'm going to have to learn something. Any advice on the front diff would be appreciated.
Next Question:
2. If I want to change my locked rear in back to open diffs, how do the C clips go on? Does the side gears hold them on?
The reason I don't want to do the real fix yet on the 3rd member is because of $$$. Ok really because of :princess: .
1> yes...you can swap front to back, the ONLY difference is the center block, don't forget to install that in the rear (unless you put the locker back in) Front diff will take a while, may as well get knuckle kits while yer in there...
2> with the guts of the diff installed, and with the center block and crosspin in your hand, install both rear axles, and push them HARD to the center...install the c-clips, and pull the axles 1/4"ish outwards to seat it in the side gear. (Odds are one will fall, and you'll spend the next 20 minutes trying to fish it outta the bottom of the housing without dropping the diff....) Hole the center block in place and install the crosspin/retaining bolt...the center block keeps the axles pushed out and keeps the c-clips inside the grooved backside of the side gears so they don't fall out.
woody said:
oh yeah, you DID save the center block when you installed the locker, right?
RIGHT? lol
of course i'm not going to throw away good cruiser parts.
on question 2. it sounds like it would be easy to just put the locker back in.
andrewfarmer said:
I'd leave the front where it is and just replace the pinion bearings in the rear - it's easier than stripping the front, and then you dont have a problem to fix later...
i've thought about taking the the 3rd to a mechanic and have him replace the bearings and do the adjusting. I've read this is something you don't want to do yourself. from woody
I'm thinking the toyota dealer here they clam to guarantee work for life.
any guess on labor cost? local garage or toyota dealer?
Labor alone to setup a ring-pinion is $100ish....and don't take it to the toyota garage...find a race shop or a local dive and ask them who the area gear expert is. I have ONE guy locally that I trust for this stuff...I DO setup my own offroad gearsets but have always taken in my daily driver stuff...I took one in to have him check it, and he said it was "good enuf for offroad..." lol...ie: it was a little loose/sloppy, but for low speed use, it's not as big a concern as running 65mph all the time.
Autozone guarantees their power steering pumps for life....I change them twice a year.
"I can s*** in a box and mark it guaranteed..." (name that movie!)
ok I think i've made up my mind. I'm going to taking out the aussie locker until I get it worked. The aussie locker is magnifying the problem. Plus my new cork gasket is leaking so i need to do something with that. I'm thinking about using dremal sand paper and then buffet with the dremal and use a little gasket maker material with the cork gasket. There is rust on the outside edge of the diff cover seating. Probably be x-mas until I can get the diff worked. Thanks for all the help.
if you need just a third member, I probably have a spare in my basement....
email me - I'm not too far from ya - over in the shenandoah valley....
bk@engsoln.com
Wes,
Might as well pick an extra third if you can...
To set up a third member with the rebuild kit (new bearings) is prob ~$400.
You can set pinion pre-load your self, but if the bearings are bad - you need a machine shop to get the inner pinion bearing off and on. A lot of times the shims spin and crack, so your pre-load is gone and the pinion starts flopping, leaking...
What did your drain plug look like? They have magnets in them - was there a lot of silvery powder on there? Or big slivers of metal? If so, your bearings are coming apart.
You could always swap your front third member to rear - fronts have no miles on them relative to the rears - put in the Aussie, then get the rear rebuilt and stuff it in front.
A couple of other thoughts - did you check clearances on the Aussie? I had to order the thickest thrust washers to get mine right.
To clean your gasket surface, use a wire brush on a drill...
PabloCruise said:
Wes,
The drain plug had dark sludge on it.
I checked the clearances and they were good. I just got finished installing the open diff and it was easier than I thought. I had a harder time talking off the aussie locker than installing the open diff. The problem is still in my rear end but it's less noticable so when I can get it worked is what i'm going to do.
Oh yeah, Toyota dealer quated me for me to bring him the 3rd member myself:
$800 :flipoff2:
They said it was like 8man hours. :flipoff2:
Pin_Head said:
Just get a good used 3rd member for $50-100. Save the old pinion gear for a trail spare in case you break one. Rebuilding a stock 3rd member is like polishing a turd. I know, I've done it.
junk yard?
Somewhere around Jan '78 marked the switch to fine spline pinion...
I think you can go all the way back to 1969 for thirds. It is the companion flanges that change - you'll just have to yank yours and put it on your "new" third - which is when you get good at setting pinion preload!
So I recomend buying a stash of shims, pinion seals and stake nuts.
