1977 FJ40 stock.
Ok i'm not very mechanical but I feel I am learning. I have a known drive train problem when I bought the rig. From what I can tell a lot of backlash. I installed an aussie locker a few weeks ago in the rear and discoverd the pinion seal leak coming out of the drive shaft side of my 3rd member. I went underneath the vehicle yesterday and found a lot of play in the pinion
and a lot of backlash. I'm thinking the pinion bearings are shot as well as the seal. The front had no play in it. So the real question is:
1. Can I swap 3rd members from front to back? and are they exactly the same?
I'm looking at my haynes manual and it looks more complex in the front axle to take of the 3rd. I guess i'm going to have to learn something. Any advice on the front diff would be appreciated.
Next Question:
2. If I want to change my locked rear in back to open diffs, how do the C clips go on? Does the side gears hold them on?
The reason I don't want to do the real fix yet on the 3rd member is because of $$$. Ok really because of
and a lot of backlash. I'm thinking the pinion bearings are shot as well as the seal. The front had no play in it. So the real question is:1. Can I swap 3rd members from front to back? and are they exactly the same?
Next Question:
