- Joined
- Mar 15, 2014
- Threads
- 13
- Messages
- 1,653
The front end was due for a rebuild before this. Any spinning of the broken pieces was at <5mph and I was being careful about turning too far in one direction so I have my fingers crossed that nothing serious is messed up.
I'm curious to see how it failed. There was no noise indicating something had broken and I was barely using the throttle. The rest of the time on the obstacle I was going straight. could have just been its time. Just got down off the rock, tried to turn to full lock and felt the front end bind up a little bit. Every now and then you could here a clunk out of the left front knuckle.
A stock shaft would be ideal since this thing is a budget beater. But I figure If I put money into building the front axle I can always swap it into another 80 when the White Trash has it's card pulled.
The thing about 37s or 40s is I really don't need or want them. $400 for a tire? No thanks. In my mind they will probably make my east coast wheeling experience less enjoyable. Where is the fun in rolling over every obstacle I encounter. I just did 90% of the hardest public trail within 5 hours in 2wd.... 35s I could probably justify because I like the 80 series gearing with 35s on the highway. But for offroad around here? Meh. If I lived out west it would be a different story.
And being liberal with the gas is fun. Just to be clear, I go very slow and will use my lockers to avoid excessive speed, but I don't mind bouncing it off the rev limiter while sawing the wheel back and forth to heat up the tires either.![]()
My guess is the cage failed, the bell might even be fine. As for tires, maybe swap them out and see how you like it?
Funny thing, you're putting the rig away for the winter when a few of my friends are starting to get theirs out over here.
