looks good kurt, might have a spare oem PTO...
Got a bit more done this last week, swapped in a new fuel pump and inventoried some of the other needs. I've updated my top post to reflect my current needs, but I'll post them here too![]()
Parts I Need: Let me know if you know of a source!
PTO Winch (where are they when I actually want one)
Bug catcher window w/s (anyone making these again?)
Tailgate
OE Carb (has Rochester but runs)
Hub caps (have later model ones I will likely use, but I'de like a full set of the period correct ones)
Rear Tailight assemblies
Rear tailight plugs for vehicle side of harness (this one has been hacked)
ANYONE??? ANYONE???![]()
I have a PTO in pieces. (the spooled end that holds wire) It came off of a FJ40. Not sure about the the gear box, I will pull a box down tomorrow at the shop and see. I will let the PTO go for cheap since it is non functional![]()
I think I have a 4 speed PTO assembly. I think Mderrick has an extra Pto shaft as well
kurt, if you have some time this week or week end you should swing by and check out the LV and the PTO i have. i am sure we can work it out since i am going to be in need of a lot of stuff from you.
Carb's done. Yours is the one on the left [one on the right is going to dd113]
Enjoy!
...I might be able to part with a headache rack, but that depends on my ability to snag a trayback for my 45 for not too much...
Keep me posted![]()
