Np. Barely pictured, but it covers the back right seat mounting bolt on the driver’s side.Please attach a pic. The seat diagrams are pretty complex and having an image will help with narrowing it down.
I believe it is 72158-60080-C0Np. Barely pictured, but it covers the back right seat mounting bolt on the driver’s side.
Can I get some help with the part numbers for these rubber bolt hole covers for the back of the second row seat brackets? Two of them fell apart with removal. 2017 LX570. Thanks in advance.
View attachment 4081026View attachment 4081027
Looking for the rubber circular trim pieces that cover the 2nd row seat frame bolts (as shown in post 402) for a 2019 US spec LC200 with black interior.
Also curious if anyone has a photo of the tailgate without the trim panel installed (had an aftermarket tailgate storage panel that I am returning to OEM, but the 4 nuts the trim panel bolt to have been removed).
TIA!!
Boots not serviced. Coil assemblies only.I’ve searched far and wide, but can’t see a definite part number for spark plug boots (or ignition coil boots) as a separate OEM part vs the whole coil. This is for a ‘21. TIA
thanks for this. I was hoping I was wrong.Boots not serviced. Coil assemblies only.
90919-02256.
I’ve seen a handful of people do them as PM but generally people wait for problems.thanks for this. I was hoping I was wrong.
EDIT: are you guys replacing these at a set interval, or just when you get codes/coil issues?
Yeah it seems like I remember someone posting that they were going to be discontinued.Question on TRD brake pads.
I have ordered the following in the past:
Front (2016+) TRD Pads - Part Number: PTR09-0C111
I have some notes on the TRD rear pads as part # PTR09-0C110 but those don't seem available anymore.
FWIW - I placed an order with Serra for the front's late last week. Now looking at my order, appears front PTR09-0C111 are no longer available either...
Yep. A few years back, they were unavailable nationwide. Then they came back in stock last year. Figured I would get another set with the online parts sale for TRD components. Oh well. Kind of like the TRD oil filters, no longer available.Yeah it seems like I remember someone posting that they were going to be discontinued.
I read on here in the past that they were made by Hawk, and that they were just a certain compound reboxed. I tried those but they did not seem to be equivalent, to me at least.
If I recall correctly, Stoptech makes those pads. I've had them side by side, and the only difference is some red paint.Question on TRD brake pads.
I have always used OEM as much as I can but avoid these websites as I cannot figure out how to read what the part number is. If someone can explain how to read this I would seriously appreciate it. Also I might look for the other two hoses and the Tee as well. Thanks
Thanks bloc! How did you get the last 5 from the parts diagram? I have it pulled up for my vehicle year but don't see the last 5 in the diagram anywhere.12263 is not a complete Toyota pert number. Correct numbers will be at least ten digits with a dash in the middle. Plus the above diagram is for a 2014.
@mbennett22 the correct number for your 2009 is 12263-38010
If you want to do the T as well that is 12233-38010
Drivers side hose 12262-38020
Hose to intake tube 12262-38050
I looked them up on a different system that isn't widely available to the public. I have seen people get good results using partsouq's diagrams but can't speak to whether these specific parts are on there..Thanks bloc! How did you get the last 5 from the parts diagram? I have it pulled up for my vehicle year but don't see the last 5 in the diagram anywhere.
