The official part number request thread
Can someone tell me the part number of or exactly what is underneath the front passenger's seat? I have a 2013 LX with the Mark Levinson system. It is an ECU of sorts that has three different plugs on it.
I cleaned the carpet (removed the seat to get to it) 5 days ago in that area with some spray cleaner as the carpet had a stain/spill on it from about a month ago. I didn't drive it until today and noticed the stereo is not working. Didn't drive in any rain and car is stored in garage.
I know the stereo amp is on the driver's side which I didn't touch so I'm trying to figure out what ECU it is. Trying to rule out if this cleaning procedure has anything to do with the stereo not working.
Does it look something like this?
Is that for the SOS system? (not sure of the proper name, calls emergency services when you push the SOS button). Can it be removed cleanly or is it integrated with other systems? I understand that function doesn't work anymore being 3G, and I could use that space for a ham radio.
Crappy picture but I believe it is part number 86104-60010. Multi display controller unit that may have something to do with the audio system. It being dry and a little dusty makes me feel a little better?
What I'm trying to narrow down now is if it is 2013-2015 LX specific. Maybe with only Mark Levinson?
Here is the same part on eBay for a full view. I did not remove mine completely. Maybe I should and blow out the connectors/let them breathe for a bit. I didn't try starting the car with anything unplugged.
First, this thread is awesome! Thanks for all you guys do!
Second - can someone help me find the parts numbers for the items circled in red?
2020 Heritage Edition.
Thanks!
Thanks!
Cargo cover 64910-60240-C0 (you won't like the price.. occasionally they sell used for much less)
2nd row middle seat headrest, black 71960-60630-C1 (I'd double check this with a dealer, there are a few color options and I believe HE's had gold stitching which I'm not seeing an option for in the listings)
On the middle seat back.. the whole thing is missing? I didn't know they were removable? If so, this is a $2700 MSRP part.. I'd strongly advise working with a dealer to make sure the correct part is ordered, and if they mess it up it's on them.
Thank you.
Looking for the part number of the map lamp lens and the passenger side cargo net hook. Any ideas on part numbers? Going blind looking at low res part drawings.
I don't see the just the lens being a separate number.
For the whole assembly:
81260-60A81-A0 "shell"
81260-60A81-B0 Light Gray
Cargo hook is 64725-60020-C0 for black
Thanks! Yeah - the entire lamp assembly is something like USD$1600 (!) which is nuts.
I’ve gotten used to every 200 series part being ridiculously priced, but this one takes the cake in my opinion. $900 for a simple cargo cover is crazy.
Somewhat complex, needs to be durable enough to go into a Landcruiser, and I think a big factor here.. very low volume.
I got mine used, and still had to pay $120+ for the plastic interior parts to mount it.
Not having my windows broken by whatever tweaker that saw a sweater in the back of my cruiser.. priceless.
there are two trim parts between the first and second foot on a landcruiser roof rack (note LX is different)
The shorter one should be in the front, with the small plastic clip holding one end down: 75551-60110
The longer rearward one: 75555-60020
For a 2021 LC, is the 75555-60020 on both the left and the right? I have seen it listed as “right molding.”
And then…am I right in thinking that we have two of these 75555-60020’s on each side of the roof?
Same number for left and right. And yes there are two on each side of the roof.
I wound up grabbing a new one for less than $500. Still stupid expensive but the part number matches the VIN which is something I care about.
@bloc I managed to not use my giant gord this morning and mangled a right rear driver side seat plastic trim piece. It’s the one next to the middle row driver passenger right foot if this helps dial it in. Black interior 2021. TIA.
Please attach a pic. The seat diagrams are pretty complex and having an image will help with narrowing it down.
I'm looking for the part number for 2014 Land Cruiser radiator grille. It has the radar cruise and front camera.
I found three different part numbers and not sure which one is correct.
53101-60916
53101-60880
53101-60A20
Thanks
53101-60916
53101-60880
53101-60A20
Thanks
Should be the 60916 number
