I'm having a heck of a time deciphering parts diagrams....my truck is missing 3 of these covers on the second row seats. I've found some variations of them on overseas eBay. Anyone have a part number for the covers? 2008 Land Cruiser
I am struggling to understand what specific part I need to order for three items. Looking at part drawings and numbers is new to me, hence the probably dumb question.
2013 LX 570
VIN: JTJHY7AX0D4113927
1. Front left and right seat cushion pads for bottom and back of seat. I have semi-aniline covers with heated/vented seats. I found the "seat cushion pad" part number 7150260211 but there are several types and I can't seem to find the back nor the right front.
2. Front grill (upper portion). What's the difference between these two? Also, the drawings show two different grills for each. If it matters, I have the "PA INTUITIVE PARK ASSIST WITH WIDE-VIEW FRONT AND SIDE MONITOR (CAMERA ON FRONT GRILLE & PASSENGER-SIDE OUTSIDE MIRROR)"
3. Front wiper blades... This is really a SQOD but I'm confused. I've found these two parts but why is one labelled left and the other doesn't label left or right? Also, I actually have one wiper blade so only need one, but I'm not sure if it is the left or right. How would I confirm? Are they the same?? The number printed on the blade is 202325A and I couldn't find a reference for that.
- 2013 Lexus LX 570 Grille. Body, Interior, RADIATOR - 5310160919 | Bell Lexus North Scottsdale, Scottsdale AZ - https://parts.belllexusnorthscottsdale.com/p/Lexus_2013_LX-570/Grille/63556639/5310160919.html
- 2013 Lexus LX 570 Grille. BACK, Body, Interior - 5310160920 | Bell Lexus North Scottsdale, Scottsdale AZ - https://parts.belllexusnorthscottsdale.com/p/Lexus_2013_LX-570/Grille/63400284/5310160920.html
Thanks
- 85222-53071 - Lexus Parts Now - https://www.lexuspartsnow.com/parts/lexus-blade-front-wiper~85222-53071.html?vin=JTJHY7AX0D4113927&make=Lexus&model=LX570&year=2013&submodel=&extra1=&extra2=&filter=()
- 85222-42110 - Lexus Parts Now - https://www.lexuspartsnow.com/parts/lexus-blade-fr-wiper-lh~85222-42110.html?vin=JTJHY7AX0D4113927&make=Lexus&model=LX570&year=2013&submodel=&extra1=&extra2=&filter=()
I need some help with my rear end.
My 2018 LC's rear end that is. Any help is greatly appreciated.
There is a metal bracket to which the bottom of the plastic bumper attaches with a couple of bolts and push pins.
This bracket is bent inward; miraculously the plastic bumper isn't cracked.
I must have gotten hit in a parking lot as I just noticed this yesterday and have no idea when this happened.
You can see from the photo that the left part of bracket is bent inward; the bolt and pushpin should point straight downward.
It looks like it just bolts to the frame & looks like it's easily removed so I might be able to bend it back.
But in case I can't I'll just get another.
I've looked and I think it's this: 52172-60050
Genuine Toyota REINFORCEMENT, REAR BUMPER, NO.2 52172-60050
Many thanks.As far as I can tell that's the correct number for your rear end.
Hey guys.
I'm looking for front Toyota grill badge part numbers for 2013-15 and 2016-21.
Thanks!
Since I believe all US market LCs from 13-21 had the radar feature I'll only include those numbers.
13-15 53141-30120
16+ 53141-71010
retaining clips are 90183-06031 for both
I suspect those aren't factory, but added after holes are drilled as part of comprehensive rust-proofing. My 2013 LC doesn't have them, and nothing in the parts diagrams.What’s the part number for the small black plug in the pic? You see the plug when opens rear door, one on each side. It’s for 2017 LX but I’d assume same as LC. TIA
Sounds like a job for a friend with a 3D printer.Thanks for the quick reply. This is really bizarre. Looks like I have to improvise finding a plug to cover it. The hole is about half an inch in diameter
Most likely from PDR. My LC has a plug like that only on the rear driver side door jamb.Thanks for the quick reply. Did a bit more research, most likely it’s from PDR. The hole is about half an inch in diameter and I can get the plug off Amazon or eBay.
Looking for the rubber circular trim pieces that cover the 2nd row seat frame bolts (as shown in post 402) for a 2019 US spec LC200 with black interior.
Also curious if anyone has a photo of the tailgate without the trim panel installed (had an aftermarket tailgate storage panel that I am returning to OEM, but the 4 nuts the trim panel bolt to have been removed).
TIA!!
Any idea what size bolt and thread pitch I'm working with? I can track down some flanged nuts and use some JB weld...2019 LC black interior
Driver's side: 72329-60110-C0
Middle two: 72329-60090-C0
Passenger side: 72329-60100-C0
Can't help with the tailgate pics..
Happy thanksgiving!
