As I recall, those numbers on diagrams are a key to a table that contains the part number and description. It takes a little but of sleuthing, or access to systems that are more user friendly to get to a part number sometimes.
Hey bloc, do you have the part number for the Pcv valve hose. Just checked all the hoses and they are all rock hard.12263 is not a complete Toyota pert number. Correct numbers will be at least ten digits with a dash in the middle. Plus the above diagram is for a 2014.
@mbennett22 the correct number for your 2009 is 12263-38010
If you want to do the T as well that is 12233-38010
Drivers side hose 12262-38020
Hose to intake tube 12262-38050
What’s your chassis build date?Hey bloc, do you have the part number for the Pcv valve hose. Just checked all the hoses and they are all rock hard.
Its a 2009What’s your chassis build date?
There will be a more specific build date on the VIN placard in the driver's door frame that includes day/month/year. Some of these part numbers change in the middle of a year model run; the PCV hose for a 2009 is one example.Its a 2009
Oh okay, looks like it is 09/08There will be a more specific build date on the VIN placard in the driver's door frame that includes day/month/year. Some of these part numbers change in the middle of a year model run; the PCV hose for a 2009 is one example.
In that case your PCV hose should be 12261-38020Oh okay, looks like it is 09/08
The molding clip holds an area at the very rear of the windshield molding. The clips themselves are glued down to spots in the lowerred slot.. the manual calls for Flexible Epoxy in that spot, but windshield techs usually just use their black urethane.hi all,
i noticed the front molding (which is in need of a replacement on both sides) is sticking up. how do these attached?
is this the piece that holds the molding down? 75561A
Toyota Roof Drip Side Finish Molding Clip #75561-52040 | Autoparts.toyota.com
Genuine Toyota roof drip side finish molding clip for secure trim retention, clean roofline alignment, and exact model-matched fit.autoparts.deserttoyota.com
has anyone replaced these? looks like the windshield area has 4 rivets? my glass was replaced once by safelite. who knows what they did...
i have the prinsu roof rack installed...i've watched a few videos and no one really mentions or goes over the 4 rubber pieces (75551 + 75555 + 75553A)...
anyone have a picture of how their roof looks with the rack? curious how the pieces all look.
Got it. looks like I can see the remaining of the clip that someone broke off..the white rectangular piece is still glued onto the roof.The molding clip holds an area at the very rear of the windshield molding. The clips themselves are glued down to spots in the lowerred slot.. the manual calls for Flexible Epoxy in that spot, but windshield techs usually just use their black urethane.
I don’t think that tape will work, given the heat it will gage to deal with sitting on top of the roof. I got some stuff from a company called total boat. Wasn’t expensive.Got it. looks like I can see the remaining of the clip that someone broke off..the white rectangular piece is still glued onto the roof.
Can I use this instead of the epoxy? https://www.3m.com/3M/en_US/p/d/v000056294/
And I am missing 1 rubber trim on each side. Will grab those too on the current 25% off sale..
found a good shot of how the rubber pieces are laid out.
Toyota parts deal translates themThanks bloc! How did you get the last 5 from the parts diagram? I have it pulled up for my vehicle year but don't see the last 5 in the diagram anywhere.
48510-69395 frontI've been looking at ordering OEM Tokico from Toyota and been shopping different dealer sites like Serra, Amayama, Toyotapartsdeal, partsoq etc and trying to find the best deal *shipped*. Just looking for front and rear struts/shocks, not replacing the springs. I'm getting conflicting info depending on driver/passenger side so, could someone post the right part numbers for the front and rears for a 2013 LC? Pic for attention:
I don't see an obvious "terra" color.. Did toyota call it Chocolate?Anyone able to tell me the part number for the second row middle head rest on a 2016+ in Terra? I can't figure it out from the parts diagrams.
Hi @bloc ,
Would you be so kind as to tell me if there is a part number for the bracket that holds the windshield washer fluid input nozzle to the side of the engine bay?
Mine is missing.
Or is it just a screw of some sort?
