The official part number request thread
Any idea what size bolt and thread pitch I'm working with? I can track down some flanged nuts and use some JB weld...
Thank you and Happy Thanksgiving!!
The part number for the bolts is 90119-06786
I went and had a look at mine and the heads are 10mm, which for toyota usually means M6x1.0
I'm trying to track down this piece of trim for 2011, does any
one happen to know it's correct name or part number?
Drivers Door Jamb sticker says 07/11 in one corner. That's closest thing I can see to a date
So this is kindof a tricky one. The part number toyota lists as being for trim panels with the seat heater controls seem to have a darker wood when I check pics of that part number online. Here's what I can find: 55405-60240 PANEL SUB-ASSY, INSTRUMENT CLUSTER FINISH, CENTER STEERING WHEEL-WOOD(BUBINGA), W(STEERING SWITCH)&SEAT HEATER-DRIVER & PASSENGER & REAR NO.1
Another wood type is as follows: 55405-60260 STEERING WHEEL-WOOD(BIRDS EYE MAPLE), W(STEERING SWITCH) (08/2010 - 11/2011)
There aren't many pics of these online to confirm though.
Given the cost of these I'd put them in the category of something you might consider working with a local parts counter on. If they get the number wrong, it's on them.
Or you can pull yours and see if there is a part number..
Ok thank you, I'll chat with the local dealers and make sure I get the right one. I think mine has the Bubinga trim
Can you order just the heater knob that fell off? I can’t seem to find it. 2009 LC. Also assume the door/spot buttons should light up similar to the garage button lights? What bulb goes there?
From memory the knobs aren’t available separately. Mine are intact so I don’t remember the specifics.. but someone might have come up with a 3d printed aftermarket solution? Maybe post in the SQOD thread. Not really a stupid question but that one gets a lot of eyeballs.
Those buttons don’t light up on our pedestrian Landcruisers.. they might on an LX? Also can’t remember specifically.
2019 LC black interior
Driver's side: 72329-60110-C0
Middle two: 72329-60090-C0
Passenger side: 72329-60100-C0
Can't help with the tailgate pics..
Happy thanksgiving!
Do you show any updated part numbers? I just got an automatic refund from the local dealership, because the parts are discontinued...
Thanks!
Thanks!
I don't. Still shows as a good number on my local site.. but partsouq doesn't return a result at all..
Might be worth trying to contact one of the bigger parts sites. Per Beno a given dealer saying something isn't made anymore is often just a result of them being lazy, vs the part truly being discontinued.
Hi, I'm looking for the rear hatch support struts, for a 2017 TLC
Also please confirm the hood supports are 53450-0W310 and 53440-0W340
Thank you
Thank you
I can't remember specifics.. does 2017 have the motorized hatch?
And what is your build date? Three different part numbers depending on specific date.
No motorized hatch
Build date is 09/16
RH hatch strut 68950-0WD90
LH hatch strut 68960-0WD90
Your numbers for the hood struts appear to be correct.
Coming up short and hoping greater minds than mine can assist. Looking for the 2019-2021 LX570 Inspiration/Black Edition parts below:
  • Gloss alloy wheels
  • Front grill
  • Rear window accents (RH 6271060J60 / LH 6272060J00)
  • Roof rails (RH 6346060180 / LH 6347060110)
  • Door handles (FR 6921060200C0 cover 6925060150C0 / FL 6921060200C0 cover 6925060140C0 / RR 6921060200C0 cover 6925060160C0 / RL 6921060200C0 cover 6925060160C0
  • Black chrome garnish (FR 7571060090 / FL 7572060090 / RR 7573060090 / RL 7574060090)
  • Rear license plate garnish (7680260240C0 or 7680160480 ?)
  • Rear badges (7547360171 ?)
  • Unique key glove
Coming up short and hoping greater minds than mine can assist. Looking for the Inspiration/Black Edition parts below:
  • Front grill
  • Window accents
  • Roof rails
  • Door handles
  • Black chrome garnish (sides)
  • Rear badges
  • Unique key glove
I haven’t heard of an inspiration or black edition 200-series. Have any more info? Year? LC/LX?
  • Front grill
  • Door handles (Front RH 6921060200C0 cover 6925060150C0 / LH 6921060200C0 cover 6925060140C0 / Rear RH 6921060200C0 cover 6925060160C0 / LH 6921060200C0 cover 6925060160C0
  • Unique key glove
Adding Headlamps and Taillamps
