Goebs; intermitant is probably a bad ground IMO...white with black tracer is the ground to that junction; got a used UGLY used junction strip that is starting to delaminate...BUT in one piece.......took the connectors apart took a dremel wire brush to them so they were polished metal then hooked everything back up and
working nicely,,,,,,,,,you might also check the ground that comes into the strip! HTH
Lou
working nicely,,,,,,,,,you might also check the ground that comes into the strip! HTHLou
wonder if that might be where the problem is;
