Superflex radius arms
Haha I am agreeing with you! When I said I would give you a body, it wasn't because I was betting that you were wrong. lol. I just like seeing cool projects.
I do think you are 100% right on this, if person doing the project could afford to cut the body (and I believe build wider ruffstuff/diamond/spidertrax housings) it would be an awesome setup.
Oh and a Turbo. :flipoff2:
Well I won't have to worry about any donations for a while since I no longer own the truck. :crybaby: But it is weird how bad they look. IMO.
Hmmm I really like the 70's lights on the 70's I would see if I could have a quick mount attachment setup on the tube so you could have them on and just pull them to wheel?
Don't know on lenses, but have a couple of sets, one from an Euro 70, that look better.
I'll donate mine from the 73.
They won't fit once the uppers are removed, to clearance 42s.... (Not mine, but to illustrate sans uppers.)
From my perspective, how can one afford not to?
I'm certain that you just forgot and aren't adding insult to injury, but a week, maybe less, before I killed her, picked up full widths to begin "fixing" the issues with suspension, as a whole....
Ain't life a bitch, sometimes?
Hurts to even hear it said.....
Still hold her responsible for swine flu....
Something will have to be figured out, but it'll be after the stretch.
Since thread has gone to pot and talking pigs/signals.....
I'll be tied to the stake in a Texas pasture overan by wild boar fit either, but have been in contention.
I got superflex arms on my money pit, they work great onroad, some good linear rate springs and a decent set of shocks will control them well onroad.
So, just out of curiosity, and from the perspective of someone who likes to 'wheel a leaf-sprung K5:
Richard sez the arms are working for him, and you say he's doing it wrong?
By the way, n=1 is "anecdotal evidence". It's not "data". That goes for everyone.
Seems like if you want flex just 3-link the damn thing.
I read some of this thread and most of what I got was about bolting s*** on and wanting it perfect. Again, I didn't read the whole thread but I read some posts about how so an so is not going to be doing anything but bolt ons. I say, sweet, then you get what you bolt on. End of story.
If you want 4"+ of lift and want the truck to handle super nice down the road, bolt ons are not going to do it. Save the few thousand you will spend on arms, bushing, plates, blah blah blah and go buy some tools. A torch (or plasma cutter), a nice grinder, a quality welding machine, a few cheap tools like digital level and angle finder and you are in business. Oh noes (!), I don't know how to cut & weld!! Big deal, learn or suffer like thousands of other Cruiser owners with bolt ons.
A cut & turn is one of the easiest "custom" fab jobs I ever have done. I had zero experience when I did mine, I just did it like the thousands (if not millions) of other people out there that have done it. Came out simply killer even if I made a few small errors a long the way. Correcting pinion angle is just one step farther, ie cut everything off the housing and make it all new. That and move the stupid tie rod in front because that lame arse tie rod behind the axle just causes ton's of problems. Will it flex like mad!? Nope it sure won't, it is still a radius arm design. But you can run 4-6"+ of lift and 37's and it can drive just like a stock Cruiser. Without a doubt.
From my experience 4-5" of lift is going to put caster out by 8-10*. That is a s*** ton and I often scratched my head when I read about 1" of lift = 1* of caster. It simply doesn't work that way, it is more of a percentage, the more you go up the more the % increases. Pinion angle probs? Well ya, the more you lift the more the axle is rotated. So you either run a DC front shaft which some say work and some say doesn't or you cut everything off the housing and set it up just like stock but lifted to your desired 4", 5" 6" or whatever.
I just don't understand why some many people spend so much money on bolt ons and end up with not so awesome results. I was thinking the same way, then I did some reading, had a few chats with some bro's and said to myself, screw all that! For the price of some welding wire, a few cut off disc and some beers my 80 went from a total white knuckle sketchy death trap ride to cruising down the hwy at 80mph with two fingers on the wheel. The alignment shop was actually blown away because I had been out by 9* when I first took it to them and then after my c&t I was spot on at 4.5* and they couldn't see any changes. They asked, what the hell did you do to it!? I said I cut and welded.
Last bit I will add, from my experience, 4"+ of lift and no sway bars is no good unless you only do slow hwy driving and slow wheeling. Anything high speed and it is sketchy, especially when it unloades. My last run in my Cruiser I had no sway bars. Bad mistake on my part and the morning on the day I rolled my truck I tested it in the dunes. High speed turn in the sand and one front wheel lifted off the ground nearly 2 feet. When I rolled later that day, it was obvious to me the suspension had sort of unloaded which heavily played a part in me destroying the truck. Had I been running sway bars, I am pretty sure I would still be driving my truck today. I had driven the exact same line I rolled on before several times, with sway bars and it was no problem. Enough side body roll, enough off camber and enough unloading and bam over it went. Sway bars IMHO would have stopped that. But with long travel shocks and steering that didn't bind, there wasn't anything to stop the weight transfer and unloading which was the root of why I rolled my truck.
Cheers
Cheers
Good post, glad you said it, and for our intents and purposes I agree. Everyone has their own opinion on what is acceptable in road-handling. I think we share similar opinions there. I may be one of the only people who installed long-arms on a jeep so I could drive 800 miles on the highway at a time and less for off road performance. Personally I'd never drive on road without sway bars, and even off road it can be sketchy. I ultimately ran Currie anti rocks on the jeep and was thoroughly impressed. Sorry for the jeep talk, but it's where a lot of my experience comes from.
I wanted to avoid a cut and turn, figuring part time 4wd will allow me to set good caster and not have to worry about driveline vibes. Also wanted to spare wear and tear on chromoly shafts. Also also was going to install low range gears, so I'll be in the t-case anyways. I'll consider reconsidering though, haha. Could always do both, kind of like burning time and money though. In my experience you gotta use at least 3 forms of measurement before you weld up a turned' axle. I may be paranoid about my geometry's though, so perhaps my experience with it was a little stressfull. Perhaps part-time now and turn' later depending on how the vibes are as I gain speed in 4wd. At least that's my thought process on this. Caster and steering are priorities that I will address, driveline vibes can always be fixed with turning'.
Anyways, no one makes a full long-arm system for the fzj80 that's validated by consumer experience, hence why I wanted to hear peoples opinions on these arms as they appear to be one of the few options for increasing articulation of the existing system. The length Toyota designed into the front radius arm system is awesome, probably the only reason I'd consider maintaining them with 4'' of lift. Anyways, yea great points. I know you don't need me to tell you that though :).
In a nutshell.
They alter caster beyond an acceptable range.
They alter pinion angle beyond an acceptable range that either a standard jointed or double jointed drive shaft can function in a circular rotation.
They do not allow retention of the front sway.
If operation out of those ranges is sufficient for an end user, so be it, but that's not how they're marketed, not what I paid for, not what I paid more to correct, to eliminate front driveline vibe.
If he's cool with it, great, and if he were to have said that I'm just a picky mofo and the driveshaft vibe, alone, wasn't that big of a deal, there'd be nothing I could defend against.
That's NOT what was said, and why there's multiple posts clarifying.
I don't give two s***s and my reply to the poster that bumped the thread was merely that the driveshaft shouldn't bind, then the facts above.
By the way....
:flipoff2:
like, i, said, im uneducated.
It can be done, but there's no market to support it.
Knowing how to cut and weld does not make one an expert on chassis dynamics.
Within the learning part, after the suffering, I'm of a mind that there's too many obstacles to overcome with the 80 platform, to improve much beyond the fundamentals inherent OE configuration.
Primarily, a huge weight disparity front to rear that's difficult to overcome and might (operative. Not starting this debate here) be why it would perform better with a relatively rigid front end.
Agree, wholeheartedly, and it's really not all that complex.
Lift 4"?
Raise the all mounting points on the axle 4".
I rolled my truck.
For posterity.
Let's say you paid that, then paid a fortune to ship, to find out that they weren't what was marketed and had to spend another $1,300.00 to correct one issue (driveshaft).
Wouldn't you report your experience, with anectdotal evidence to support?
Absolutely. I'd be pissed!
In a nutshell.
I recall my truck being pretty even front to rear. Like within 150lbs or something. Been awhile, perhaps my mind is not as sharp as it once was but I swear it was good. And I agree, there are better platforms if you want a truck that can "do it all". But 80s work pretty good at one thing or another if you set them up right. Always a compromise one way or the other, I preferred mine to be offroad since locked axles take a truck a lot farther than an open diff truck and road manners matter more to me in a DD type vehicle. Simple as that.
Cheers
by the time anyone reads this whole thread they could have linked their rig and been done with it
Cheers
Whoa a man with common sense, you sir have it wish more people could get it :flipoff2: I salute you
