Superflex radius arms
or....you could three link it.....twice as much flex, and you could use the money you saved to buy new tires!
The SE arms don't alter the suspension geometry (let's not start that again :flipoff2:) and offer plenty of flex. Highly pricey, though, and they don't allow the front swaybar to be run in their current form (last I looked a few months ago).
A three link and thornbirds right :flipoff2:
Nay- The video shows you can use the swaybar with them.
I'd love to do a 3-link but as much as I tow and drive on the road, drivability is my number 1 concern. With these arms, it looks like I can maintain on road manners and gain significantly off road. The flex is quite impressive.
Anyone have these and can chime in?
Driveability on road is as good as, and can be better tham a stock setup. No 3link compares. Driveability is also excelent when not running a sway bar.
The only down side is they need the weight on the front to make them flex as there is a certain amount of binding in the design. So they don't max out when going up steep uneven ground.
For all out flex 3 link or a x-link is better. Personally i'd use a x-link over a 3 link.
My arms flex like that or likely better. I makes a huge difference in the '80 ride comfort and ability. Can cruise stuff unlocked, where others wheel lift, have to go for the lockers.
What is the "landed in the US" price of those arms?
I think the best set-up by far for both on and offroad is the Rubicon Express long arm kit as seen here https://forum.ih8mud.com/80-series-tech/294260-jodo-97-lx450-coilover-project.html
y-linking the radius arms would be relatively easy (the coilover should allow a lot of tuning that you won't get just with a y-link radius arm setup). I am not sure you can say that it automatically retains the stock suspension dynamics onroad, because the binding in the front does more than just limit flex offroad, and a y-link with bigger bushings is a different design (what is fundamentally common is both are radius arms).
I've run this design in the past, and it is not without compromises, which is why I like the SE arms: you are gaining good flex, but without dropping the inherent suspension design. I don't think you could mod the front end of an 80 more predictably, and that is often worth the $$$ spent.
To the comment that they need some force to flex, this is a good thing in my mind. The 80 is so good at planting the front end and climbing. Some resistance straight on keeps a lot of stability as long as it will flex when you need to. Jeep owners of long travel quad coil suspensions have introduced "anti-rock" swaybars specifically to keep this resistance in the suspension dynamics without limiting available flex.
My point is that not every situation is a "twist all four corners while the body stays level" pic shot, and any 80 series suspension design that begins to trade stability for raw flex should be carefully considered, because you may be trading one problem for another.
The SE arms strike me more as an "optimizing" solution rather than "re-engineering". Anybody who has been around hardcore SUV platforms for a long time may understand how difficult it is to get far away from the base vehicle factory design, and when you optimize rather than re-engineer you will maximize your time on the trail rather than in your garage and minimize your money spent over the long run.
Just some food for thought :hillbilly:
Well said Nay :clap:
There seems to be plenty of guys on here who wheel the hell out their trucks with the stock arms including myself.:meh:
I think that most are happy with their rigs capabilities on and off road.
If it aint broke dont fix it.
Or go out and get a tubed out mini or zuk.
The 80 will never be a full blown rockcrawler unless, like Beno said, you break out the sawzall and the trailer.
I agree.
I've seen stock 80 fronts do every trail out there. Not the Hammers, but everything else.
They do it with gusto, but they get it done.
And this includes the stupid things I've decided to try my 80 against.
:lol:
I always wonder with threads like this why people want to make the 80 series what it is not? Or, was not made to be?
Unless of course you are going to plant a V8 into it, hack the body, and trailer it to the trail head.
:hillbilly:
I think going with the SE arms is far from hardcore and is still within limits of the original design. Personally, I'm just trying to relieve some of the binding in the front end and gain a little bit more flex. This may not be the magical solution but it sure helps.
None of us know the exact design limitations because none of us were on the Toyota LC design team in mid-to-late 80's when the front radius arms were designed and implemented into the 80 series, then the 7x series vehicles.
But we have all seen the possible weaknesses of a 3 ton vehicle on a 4 link, as well as a 3 ton vehicle with a 3 link. Anyone who tries to argue that the suspension and design of a 3 link are within factory design specs. is fooling themselves.
In all truth, taking a 4 link 3 truck and driving it like a car is foolish; anyone trying to do this with a 3 link is even more deluded.
You can only do so much and still have a modicum of "drive-ability" with these rigs.
Seeing as though the AUD is about to level with the USD id say it would cost you around $1450 USD landed, just as a rough guess going off what shipping has cost me from the states before.
