Good, cause there ain't a Rosetta Stone, yet.
This design does work, for what it is.
Address pinion angle and drive shaft length, not half assed spacers, TC shims, or part time kits and it'd be a winner (without a double, double) all things considered.
Talked to two different fabricators about built up arms, not cast and not machined.
Both stated it's not enough of an improvement, from an articulation standpoint to warrant the expense (they build real suspensions, not lift kits), BUT it would address two issues with these, first being weight and second ground clearance, both were around $1,700 to $2k on just the arms, as a line item on a more complete scope of work.
Still goes back to a one size fits all type scenario, which we know isn't the case in 80 ville.
The nomenclature "Four Inch Lift" means squat. It's a coil that may have achieved 4" over the OE on whatever weighted test vehicle they engineered for, but can't be a representative sample of all, and the terms "medium and heavy" have about the same note worthiness.
I realize I'm I do not represent the vast majority of 80 owners, but you can have you caster and flex, too, it's just going to take more than what shade tree engineering is capable of producing and take more money than what the market can sustain.
If pulling the front bolt is a poor mans three link, this configuration could be considered (based on merits) very similar, without undue stress on the housing or mounts. It is an improvement over OE, does drive well, and will be determined that caster is within an acceptable range.
Honestly, I don't think that's too bad a deal at $1,250, but it'd have been a whole lot better if it's been part of an entire kit, holistically addressing the front arms, rear links, coils and shocks.
That's what I wanted and couldn't find and why I've had issues, my own doing.
Think someone should take a new look at completely addressing the 80, with disregard for the cost difference in OME and a quality, tuned shock, put a price tag on it and sell it.
I've praised Icon's holistic approach to the 120 for year even though I've removed all Icon components, but that works on every platform 100 and up.
Reason why, in my opinion, is the perception of owners expendable cash, but also because its been said for too long "love the 80 for what it is" and "it's a station wagon, not a crawler" which, to some degree, I agree, but there's room for improvement and blank slate for a US innovator/entrepreneur to actually take charge of.
"It'd be easy to declare the entire OE unit a POS and abandon, but myself, I choose to find a more elegant solution"
-some wise (ass) 80 guy.
