Superflex radius arms
[QUOTE Just wish that I knew then what I know now, being the fact it is impossible to address caster and pinion angle within the given OE housing, period, because it might propelled a different direction, altogether.[/QUOTE]
.. time for a diamond :). Just curious how high are you lifted?
For what it's worth, I run Delancy's SE arms and I have experienced NONE of the issues he continually states.
Now that I'm sure he cannot wait to send me a reply explaining, in his own special language, how wrong I am, I will repeat that. I have had NONE of the issues he continually states on this forum about the Superior Engineering Superflex Radius Arms.
Appears to me you've a whole new set of new issues....
The binding is limiting the front end's full ability. The way it is right now, it flexes to a certain point and then has to force. It's also bending the brackets slightly and I wish to avoid that. Have spoken with Kevin about it many times and while the SE arms are slightly narrower than the stock arms, they aren't narrow enough. Compare these two, you can see the waviness in my brackets:
The arms also get into the frame quite a bit on that end, so I will look at what can be shaved there, too.
As far as the coil debate, I'm good with what I've been running. Has manageable road manners and works well on the trail for the things I want to do. Even without the front sway bar.
But all this is probably best discussed in a thread devoted to arms and not coils.
I see that Kevin also bent his panhard bracket; I need to up my game.
There are particular, undeniable truths inherent to the arms, that cannot be disputed, in any way shape or form. Therefore not an opinion, beyond ROI, in which case mine is there not worth the money, when coupled with either the band aid repairs (PT, double/double DCs) or the expense of doing it right.
None, now, nor will I again.
Translate, please.
I think I would rather the "whole new set of issues" that I'm dealing with than the ones you had...
I used to think I was a technical guy up until I started reading this thread. So in my layman terms this is my findings.
I have had my 80 for just under 10 years and wheeled the crap out of it.
I ran a 4" OME J spring lift with the L shocks and 35" wheels. It was a real all round machine. Meaning great on road and great off road.
I could load it full of gear pump the tyres to 3 bar and ride at 150 kph on the tar for 500 KM. At the trail the truck would work like a well oiled machine.
For me it was time for a change. I wanted more out of my 80. After lots of research and reading lots of good write ups on the Australian forums I opted for the Superior suspension 6'' super flex kit. I have to also admit that when I contacted them they did say they don't recommend the 6'' lift for the 80.
THE BAD !! ON ROAD.
Fitting this kit changed my truck. It took away that happy medium, That great on road and great off road. I believe because of the height and the larger tyres, there is no more heigh speed travelling. Anything over 100 KPH and she had like a ''speed wobble''. At this time I had no sway bars in. (the kit did not supplier spacers for the front sway bar.) The front sway bar could not be fitted as it would catch the front drive shaft. The spacers I was running with my 4'' lift were now to small. I had 2 x new aluminium blocks made to lower the bar as not to catch the drive shaft.
After resolving this part the truck ran ''fine'' a little loose at speed but ''fine''
THE GOOD !! OFF ROAD
I believe due to the combination on 37'' tyres and the improved ground clearance.
This thing is a tank. The flex is unreal there is no stopping it. My biggest regret was not fitting a roll cage.
Is the front flex more than the standard OME 4'' lift ? Yes.
There are a few factors to my assessment that I think should be pointed out.
1. This suspension was designed for R.H drives and mine is Right hand drive. There should be a few factors to consider when fitting to a L.H.D
2. With out the front sway bar this thing can flex.
3. Manual hubs in front. I will always argue that this is the best thing for any 4x4.
Why would you want all that turning upfront on the open road?
4. If you have double lockers 5.29 diff ratios and 37'' tyres. How important is huge wheel travel if you are not running a competition truck ??
All my off road pics are on my work computer will post some next week.
You mean those you were made aware of, pre-purchase, that are documented with measurements, angles, and tons of pics?
Caster and pinion angle were both incorrect, the axle relocation lengthened the front driveline, and axle housing rotation allowed tierod to contact housing.
It appeared they split the difference between correcting caster and pinion angle, creating a variance (measured in degrees) between the two pinion flanges that wasn't correctable in any manner, besides a longer, custom jointed driveshaft [*] that costs nearly what the retail price of the arms were. [**]
The housing rotation also presented issues with tierod [***] contact at the third, between 7/8 and fully locked, at ride height, on level ground. Being in no position to have checked when wheeling, can only add that it did occur, still have both the tierod and axle, and the running is still evident.
I'm going to assume you've a financially motivated interest, because it's the only reason I can see that what's been reported is being questioned, but, before discounting mine, go out and measure between pinion flanges, check caster, check the pinion flange angles on your vehicle.....don't measure with butt dyno because it's of little value to the conversation.
Report back and if, somehow, yours is correct, I'll gladly clarify in each and every post made about those issues to that effect.
[*] The first observation made about the pinion flange angles was by a notable 80 guru who checked in person, after a test drive that had him thinking he'd forgotten to tighten a wheel bearing, due to excessive vibrations.
After, I picked up a digital angle finder, measured, documented and spoke to three other indisputable guru's, that confirmed it was fawked.
[**]Which finally led to High Angle Driveline. At that time, checked all again, documented and sent to Jesse. He requested a double take, so replicated to produce the same results. After head scratching on the why, he built the shaft that I ran, being the double double cardan that cost $1,300.00.
-translated-
Didn't make the s*** up purely based on butt dyno, regardless how much even I enjoyed the butt dyno test, since the drive would produce funny feelings in places I didn't know had receptors.....but AFTER THE JOY, turned irritating.
Based on measurements, that professionals reviewed.
[***] An MAF HD tierod that was ~3/8" larger than OE. It shouldn't have mattered, but so that data is presented.
Other notes:
Guru set up axles (month, maybe two, after I installed arms and coils), checked and knew then there was an issue with caster or that it wasn't corrected.
Furthered with two caster sweeps, the second to substantiate the first and both were the same.
Part time would've corrected the on road vibes, but couldn't have ran in 4wd above 30-35mph, and did wish to achieve those speeds without the vibration.
All axle components were brand new OE, where possible, professionally set up and installed, save the axle housings, the diff housings (all gears and bearings new) and knuckles.
Transfer case was torn down and completely rebuilt with all new OE parts, where possible.
Steering was never right. Although it's not something that can solely be blamed upon caster, readings placed it firmly in what I described as "darty".
Few other observations, but they'd fall on deaf ears, as the warnings from the same guru's did on mine, when they tried to explain me why the claims couldn't be substantiated.
For the record, whatever you've inferred from my posts include more than a discontent for the arms and I never laid blame for the catastrophic failure on, nor do I maintain any ill will towards the producer, enough to slander.
Facts are facts and I'm fully entitled to voice my opinion when it comes to perceived ROI, substantiated by the above documentation and experience.
Edited: the previous post reminded me that the front sway couldn't be maintained. Another issue initially, that was stated otherwise.
Here, it's "triple locked" and tires, but agree, nonetheless.
Add to that the nominal gain the TC gears afford and it's a formidable machine.
Contend that ground clearance gains should be granted with tire, metal should be removed from tire path, and with the above modifications, could wheel hard, then hit the highway at +75mph without any ill effects.....beyond mpgs reverting to gpms.
So my findings with the arms are as follows.
First, I run them with OME J springs front and rear, a 1.5" spacer in the front and the OME shocks. I still run both the OE driveshafts and only a rear sway bar, no front.
Second, the flex they offer is much easier than most other radius-arm setups on other Cruisers out there. The biggest issue I have with them right now is that they bind on the brackets like the stock arms do and I believe it stops them from achieving their full potential. Bracket binding is when the arms touch the brackets they're mounted to on the axle, stopping their side to side movement and slowing the suspension's ability to easily move through its entire range of motion. This is something I plan to address by narrowing the arms slightly and having my bushings narrowed on a lathe when I get around to finally replacing them. This solution has proven hugely successful on other rigs in AZ that I wheel with, so I'm looking forward to this and seeing what it does, if anything, to help.
Now, the "issues" with the arms themselves.
To say that these arms bolt right on is not entirely accurate. The US rigs have a different brake line arrangement than their Aussie counterparts. This was the first obstacle I encountered and rather than bend the hard brake line out of the way, the brake line mounts were bent and with the help of a friend, a new hard line was bent around the new location of the driver-side arm.
I was made well aware of the fact that the pinion angles would be completely wrong and that the only way to properly fix it would be to cut and turn the axle, resulting in a ton of work I had absolutely no interest in doing. My plan was to address this in an easier method; by doing to the washer mod on the axle mounts if things really were that bad.
Truth be told when I bolted the arms on, the difference in steering was night and day. The truck wandered around a bit with the stock arms and no caster correction, so this was the first thing I noticed, it went away and the rig stopped trying to follow every groove and line in the road. Awesome.
But there was the drive shaft shakes in the front. Immediately, I noticed the wobbling and it drove me insane. Not awesome.
Drove it that way for about a week, asking Delancy about his super-special double double-cardan driveshaft, scared that I had made a huge mistake by installing the arms. Asking my fellow Cruiser buddies about the issue got some ridicule ("part-time kit!") and a few suggestions, the first of which was to switch the phasing in the driveshaft and see if it helped the problem as it has in other trucks out here with the same amount of lift.
So without measuring the pinion angles or getting extremely scientific, I unbolted the front drive shaft, rotated the slip yoke 90° and bolted everything back together.
To my surprise, the wobbling went almost completely away.
I was in disbelief after all I had heard, so I crawled under a few other trucks to check out pinion angles. I was within 1-2° of a couple others (one of which had the old, tubular 4-5" Slee arms on it) and the very slight vibration I now had was very similar to what they experienced as well.
This slight vibration and occasional "grr" would concern me, but one of the rigs has been running it this way for about ten years and no buses full of nuns have perished yet. Needless to say I stopped worrying about it.
Again, I'm sure Delancy will definitely point out that I am hugely wrong, but the guys I hang out with, who have ridden in my rig since I put the arms on, have said I should not worry. I'm not trying to offend him or anyone here, but I trust and value their opinions and I'm confident that, as with anything else on the rig, maintenance and inspection from time to time will help me keep an eye on it.
For those saying that I should express concern over even the slightest vibes or noises, I would refer to what several of my buddies have said, in fact, here's a quote from Beno (altered slightly for relevance in this thread), which is one of my all-time favorite posts on this forum:
What I am trying to say (as someone who has been driving a very large 80 for ten years), is that getting rid of driveline vibrations is going to cost you a lot of money if you throw parts at it.
Or if you half-ass it.
Where it boils down to is so what, what's the big deal if it vibrates a bit? You are driving a 3 ton truck on massive wheels, on massive tires, with very significant driveline modifications.
This isn't a fxxxing Corolla or a Honda. It is a Toyota Land Cruiser.
Just cruise the truck and enjoy, man. Some vibrations after the thousands of mods you have done to your truck are pretty much guaranteed...
...Otherwise, you are wasting your time.
And with that, I'm done. The arms work pretty well, but as with ANYTHING there will be some compromises. You can toss your AMEX at the issue, or you can get out there, go wheeling, have a blast and see some really cool s*** out in the middle of nowhere that comes along with experiences you'll be laughing and smiling about for years to come.
I know I already have; pretty sure I still will.
Bet on it.
Going to preface with my intentions of not trying to sound the a******.
Take that for what you will.
I'm certain what follows will be bitched about, both because length and verbiage, but understand I'm trying to assists on a few different levels with actual, factual quantifiable data, as well clear my name in no uncertain terms.
Your findings are subjective-translated "butt dyno".
Nothing wrong with offering an opinion, I do it all the time, but be cautious on who you call out and what you state as fact, if for no other reason than the amount of new guys that'll read a post and immediately whip out a credit card.
Not the purpose of this forum.
Because you're buddy runs a 6" Slee and his butt dynometer finds it to be as predictable as an OE 80, doesn't make it factual. The statement is contradictory to all physical laws, how they impact chassis dynamics, and also what the guy whose name is on the lift will adamantly exclaim.
First, I run them with OME shocks.
Then you've not begun to unlock the "potential" those arms or even OE arms afford.
BUT, that's ok, because if you're wheeling, or driving over speed bumps at the mall, going to blow the seals on the OMEs soon enough (unless you have installed limit straps, or some other corrective measure that doesn't allow the shocks to top out) and can get it right, then.
Think I'm wrong?
Take a few measurements:
First, measure the shock length, from pin mount surface to pin mount surface at ride height.
Second, let the axle droop to the bottom of the shock travel, measure and note.
[If you've a 5" lift, there's 1.75-2.25" of droop, based on OME L's extended lengths.]
To highlight the gains with correct travel shocks (and coils, but will come back to that):
Remove the shocks, repeat the above droop measurement. (Unnecessary......illustrative, since we know you'll rip the brake line from the frame, before the draglink and panhard will bind enough to stop it.)
Now, you've established the limitation of the extended shock length, which is painfully obvious how it effects axle droop, but more to check as to how it effects "flex".
Put one side shock on.
Stuff that side, measure the opposing.
Droop that side, measure the opposing.
This illustrates how having too short of a shock can effect the axles ability to articulate.....and how with only the axle weight, the fact that the panhard is in play, acting like a lever, when the shock is too short, puts pressure laterally on the axle, itself.
-translated-
Prolly why your axle mounts are bending. You're putting a lot of undue lateral stress on the axle housing, when it's articulated, as I noted when cycling with only the axle weight, NOT the entire weight of the front corners of the fat ass 80.
[will edit with pic that should illustrate this, along with several others illustrating the above process, taken during the 4-5 hour process of cycling the suspension, on a frame lift.]
Armed with the above data, which is all documented somewhere in an overly verbose, epically proportioned thread, already, you can conclude yourself, that the shocks (and coils, but later) are limiting the front (and rear) axles ability to move.
I do think that opposing panhard and drag links would alter this, but irrelevant to the fact that, when discussing, no mention was made and ALL were very well aware a LHD application.
I still run both the OE driveshafts...
Then you're shorting the slip yoke's contact by an 1". I don't recall what the total joint travel is, but that's bound to be a decrease of 25-33%.
You also reported that you swapped the front phase and this eliminated driveline vibrations, which I do believe it can.....for a little while.
Your reports that pinion angles are within X degrees of similarly lifted kinda have me thinking you may not understand what needs to be measured, because it's only the correlation between your two output flanges and your driveshaft that matter.
SO:
First, take driveshaft off and measure from between the bottom, center, and top of flanges. (This should be done at several positions of the axle, typically, but the 80 isn't capable of overextension/compression of the driveshaft, so not necessary. You'll need these dimensions to order driveshaft from Jesse, so hot them down.....or just buy mine and call it good.)
So, take digital angle finder and assess the difference between your two output flange faces, you'll see why altering phase is a temporary fix [that may have pushed the out of round rotation to the TC output flange, which will inevitably force seal failure, then bearing, then the aluminum itself].
The difference between the two precludes usage of a conventionally jointed driveshaft, that can only function in a circular motion when the two faces are the same angle off the driveline angle.
(Back with pics)
For instance, Toyota set the front up in a broke back configuration, showing the flanges do not have to be parallel, but have to be the same angle from the driveshaft angle.
Your measurements will also show that a double cardan shaft won't spin circularly, since that requires a 0 degree difference between the front output flange and the TC's.
-translated-
Front diff has to point at the TC flange, I think, within 1 degree of accuracy for a double cardan shaft to function.
Here's what I experienced and when I use the subjective term "vibrate" I don't mean like one with a couple of watch batteries, I'm talking like a Sybian.
Had the OE front driveshaft installed and I crunched the slip yoke, because the front sway bar (that I was told I could run) contacted the driveshaft, enough that I couldn't (6', 220lbs) compress nor extend.
It did NOT vibrate, but it was also under pressure that inevitably would pose a big issue, like pushing the TC flange into the housing.
I borrowed a 16 year old double cardan shaft (one of the first distributed by Slee) and it DID NOT vibrate, but it was tired and too short, by 1-1.25".
So, swapped with a freshly built double cardan shaft and it vibrated so much it could be felt in the steering wheel.
That's when the discussion began and when determined the angles were too far off to allow anything but a double, double cardan shaft to maintain a circular path, because it's kinda like a wet noodle, with no given flange face effecting its rotation.
The numbers don't lie.
If yours doesn't vibrate, great. More power to you and I'm being sincere, but it's because of other contributing factors, ie bearing wear, driveshaft wear, and so forth.
Everything on mine was brand new, so if there was to be a caveat from the manufacturer that one could only use on a RHD vehicle that the joints/bearings has a few miles on it, then I'd bear responsibility, but that was never uttered.
Most other would insinuate multiple.
I know of one other that still produces and he didn't tell me what I wanted to hear, so, due to lack of options, the SEs were the only choice.
Rubber bushings have misalignment characteristics very similar to a heim, except they lack the ability to stop themselves from exceeding beyond it.
The bracket binding on the arm is about all that can prevent from the bushing from fatiguing prematurely, by disallowing continual, excessive punishment, and that was (edited: probably) calculated into Mr Ts equation when he designed the arm thickness, mounts, bushings and so forth.
Granted, we want to push past the OE abilities, but there are instances where that simply isn't possible with OE parts, since even Mr. T's bad ass bushings will fail prematurely....and they're the best out there.
Previously stated why there may be limitations on your axles ability to articulate, which may offset whatever perceived limitation of the bushings.....so think you'd create an ongoing maintenance issue by altering the arms thickness and have other means to open up the front end, without modifying.
The bracket bending is because of a lateral force pushing against it, so increasing the distance the lateral force CAN leverage itself against, isn't going to stop it.
Take that for what it's worth.
Say this were advisable and were to produce the baddest assed 80 ever, it'd be worth considering replacing the axle mounts with heavier steel and simultaneously reinforcing, instead of altering the arm thickness.
Two cents that can be tossed in the gutter, but a thought.
Again, if you'll check the above, you can eliminate a lot of unnecessary work for a marginal gain in articulation......I'll stay away from my observation that the front's ability to articulate is a marginal gain, in the wheeling reality, since it's better to push than pull and a wheel on the ground serves little purpose if it's no downforce from corner.
I was made well aware of the fact that the pinion angles would be completely wrong and that the only way to properly fix it would be to cut and turn the axle....
You weren't listening to what I was saying, which I agree was a lot, but wanted to make damn sure you were fully aware of all aspects.
Cut and turn is for caster correction.
Rotating the axle housing would've been what I said, if doing it right, without the $1,300.00 bandaid front driveshaft.
I'm sure I can find transcripts, but with no uncertainty am I clarifying that I never said C&T corrected pinion angle.
It either does or it doesn't, but it'll kinda sorta mebbe worsen.
Because it's what you wanted to believe.
Not knocking. I heard what I wanted to hear when sourcing, against the sound advice from numerous old hats to the 80, but I admit it and paid a hefty price to prove them right.
Is the busload of nuns the barometer of success or fail?
For the record, it wasn't mine.
I knew I had failed early on with the TOTAL SUSPENSION, but even then, didn't grasp the ramifications.
Listen, man, I'm happy for you.
I was very concerned about selling any of the parts, but you've eased that since you're overjoyed.
Here's what you're missing, stated reluctantly, because I know misinterpretation will be possible:
I didn't set out to build a marginal 80...
Planned for a year, while searching for the right candidate, all the while knowing that it would be an extensive mechanical restoration, guaranteeing my lifetime of use, to the nth degree, as well this tag line that can still be found on posts from many years ago, was constantly used with each and every vendor or guru with which it was discussed.
"not only do I want to wheel all day, then safely drive home at 75mph, I want my wife to be able to do the same."
Anyone worth their salt told be it wasn't possible, but proceeded to believe what I wanted to, and invested a lot of money, and I mean A LOT of money, to have failed miserably, because I didn't listen except to those that told me what I wanted to hear, regarding suspension.
If I opine the arms offer no ROI, I'm saying it based on a lot of factors that I don't think you understand, the reason why I even went that far with it.
I'm not attacking credibility, but a lot can be inferred from this post, which I still don't understand unless you've a group buy on the horizon:
That you've since either agreed that the issues exists, or almost kinda but not really don't know if others may or may not.
There's no disputing the following:
They DO NOT correct pinion angle.
They DO NOT correct caster.
Which are the two items that I've discussed when addressing the inherent deficiencies.
For those saying that I should express concern over even the slightest vibes or noises, I would refer to what several of my buddies have said.
That doesn't justify saying you have no issues with the arms, it means you have agreed to disregard them.
That's fine, I don't give a s***, and more power to you and yours.
It still doesn't change the facts.
I can bet it was on a thread about flex, three link, long arms, or any number of those discussing the deficiencies of the OE radius arms.
Having eaten crow at beno's table more than once, I now completely understand and agree with his "embrace her for what she is and don't try to make her something she's not" sentiment.
That said, have you seen beno's 80?
Might want to consider the source...
(Edits to follow. Concerned the efforts will be lost on iPhone)
Like I said, I'm done. The arms are on my truck, have done a lot of miles both on and off road in them and they're working for me. If anyone would like to speak with me about them, please PM me.
:moon:
Nice write up Chris.
I think in this instance it is clear that there is just a differing opinion between the end users with those arms. One wanted it perfect and one just wants it perfect enough for his purposes. You see this in every aspect of the automotive hobby.
I very much applaud your path Chris and I wish it were how most people (especially companies) approached creating new products but unfortunately it is not.
I think your data is well proven and shows people the things that happen with the arms, but not everyone needs that level of detail and like for Richard they work fine and that is completely okay too.
Lots of different ways to skin a cat in this game and everyone will be okay with different levels of fur in the meat.
^prolly the most commas, in one post, ever...
im, uneducated, and, compensate, with, over usage, of commas and .....
Done with what?
If you've a rebuttal, by all means, but please include tangible information.
I think in this instance it is clear that there is just a differing opinion between the end users with those arms.....but not everyone needs that level of detail and like for Richard they work fine and that is completely okay too.
If a company said there was some killer turbo that produced 800hp, maintained OE cooling, no negatives whatsoever and you bought, dyno'd, drove long enough to realize that the claims weren't correct and that it may lead to other issues, say HG failure or whatever, by you stating your dyno data and other corroborating evidence, would that be an opinion?
No, you're stating the facts.
If I called you out saying that you were the only one that had that issue, borderline inferring you've some malicious intent, then claiming that, not only does it produce 900HP, but it fixed my leaky headgasket, does that mean our opinions differ?
No. Yours wasn't one, to begin with. I'm making claims that are unfounded and sure don't have enough information to throw you under the bus......
Your punishment:
My OPINION is, you screwed up!!
Haha I wasn't saying that your statements were opinion. They are indeed the facts. I was saying that your desire for perfection is where I said others will differ ;) I was quick to say I appreciate it! And you go and punish me. haha. That is a new picture I haven't seen. Was that from when Eric had it or is that recent? lol.
**Edit nevermind I just saw the t-shirt with 2015 on it. lol
****Double edit, who ever owns it now needs to get that piece of s*** skyjacker steering stabilizer off it and get something more inline with the rest of the truck! :flipoff2:
*******Ok @Delancy get your ass back here and tell me more about that picture! haha. Is that Beno's 70 series behind it? Is it still owned by the dealership family in Alabama??
Done with what?
Your punishment:
Grovel moar.....then I'll talk.
Onur's gonna kick your ass for mistaking, I can tell you.
It's not about perfection.
It's about the fact you can get one or the other right, because you can't have both without divorcing pinion angle from caster.
So someone doesn't care if the shaft vibes or steering is impacted, fine. I'm not judging they're expectations.
I AM saying it ain't right, which it isn't, and representing it is a such ain't right either, no matter who can live with it or not.
Call up Christo or Ben and they're gonna shoot you straight and THAT's the way it should be.....if the idiot on the other end of the line will hear more than he wants to hear.
It's my opinion that the marginal gains afforded with any known, off the shelf shock/coil combo aren't worth it and I know of no coil that will keep up with a correct spec'd shock and/or the gains the arms can achieve with.
It's also my opinion that, if you want a true dual purpose 80, one you or your grandmother can hop in and drive across town on the highway, the way to approach is with 5.29s/TC gears/39s with stock coils and arms, cutting anything out of the way that impedes wheel travel.
If it's ok to kinda get the suspension right, I don't see why it's not ok to kinda cut some metal and I'll put my money where my mouth is.
If someone has a complete body they'd be willing to wager with and assist swapping it on my roller, I'll mount 42s even, return suspension to stock and compete.
We race 84 miles at highway speed to wheel, wheel and see If I can keep up, then race 84 miles back.
I lose, I pay the predetermined fair market value for the body, otherwise it's mine.
I think that is a very apt description. I agree with you that if you can stay stock height and cut you are going to have a much better outcome.
I think that 40's on an 80 with chopped fenders would be badass. If I were going to do it though I might throw wider axles into the mix. Something like 69" WMS-WMS, gets the tires out away from rub spots like frame in the rear etc, plus it gives you a little more stability with the higher COG just from the larger tires.
If I had a spare body lying around I would just give it to you so I could watch it happen. But I am having a hard enough time as it is with the two that I have. lol.
I wonder what is up with those 70 series turn signals on the pig?? They have not weathered well at all. The orange is completely faded. They were OEM Toyota from a mine truck in Canada. I wonder if the mine truck quality is subpar, perhaps less UV resistant since they are supposed to be underground? Lol.
Realize that doesn't sound enticing, so I'll go one further.
Your body, your assistance swapping.
My roller, which is documented in detail and the amount invested can be assessed from thread, but we're talking a lot of money, on 42s.
Same deal, except I'll sign the title over if I lose.
THAT's how strongly I feel about it.
Don't know on lenses, but have a couple of sets, one from an Euro 70, that look better.
I'll donate mine from the 73.
They won't fit once the uppers are removed, to clearance 42s.... (Not mine, but to illustrate sans uppers.)
