Slee 4 or 6 inch?
I have a picture at home of Spike at 33* IIRC. I peeked in his window and took a pic of the gauge. IIRC he said something like "&@$# take the pic already, I wanna get off this! DON"T LEAN ON THE TRUCK!" :D
this pic?
this pic?
Sure.....that 6" looks tippy better go with 4" because you will roll that 6" for sure:rolleyes::rolleyes: Leave the 6" to those that Know how to drive:cool::cool::lol:
Let's look at eneven terrain. Cruisers are rated to 45* off camber....less of course lifted. I feel my LX is stable in a spot like this too. It's not as stable on twisted terrain.
45*? I never knew they had a rating. I'd be scared out of my mind in my wife's stock 80 at anything over 35*, good to know it's not a problem. It always feels worse in the seat. You sure that rating's not about climbeable slope?
If you're lifting a wheel, it will feel 'tippy' because it is tippy. If the truck is balanced on two wheels, it's gonna sway in the breeze. That doesn't mean it's about to roll. I agree it's uncomfortable.
The shot above was at 33*, that was the first time I played around with the angle finder to see just exactly where the truck was when it felt really bad. I was sort of disappointed to find that 33 degrees was my personal threshold- it felt like the truck would go over easily. My 3 passengers that day agreed wholeheartedly with that conclusion. :D MadBaggins' pics are from a later date, when I did it again for pics (shameless poser :D). For the record, that's a Slee gen2 6" lift on stock wheels with no spacers and true 35" tires. Front swaybar removed.
Something to take into consideration is the lift components. Slee's springs are stiffer than some others. Stiffer springs will hold the body more parallel to the axles. Softer springs will compress on the downhill side, allowing the body to roll farther- putting the weight of the truck farther over. The drawback to stiffer springs is less flex, which is also their advantage. There is no perfect lift for every situation, until someone makes one that can adjust parameters on-the-fly, essentially auto-levelling (which some cars/trucks have, but I don't think their systems are quite up to the task of rock-crawling :D) I would venture to guess that softer springs would give more 'warning' that the truck was about to roll, and probably 'feel' worse earlier, while stiffer springs would probably have a more sudden 'breaking' point.
Obviously, going higher is going to increase the risk of rolling. You have to decide what you want from your truck. Six inches gives better break-over and approach/departure angles than four inches does. That advantage comes with the disadvantage of a slightly higher center of gravity. Spacers can alleviate that, but then you might have problems with tire clearance. Cutting will alleviate that, but then there's cosmetic challenges. And on and on and on...
-Spike
I felt at though I was going to roll MUCH more often when I had Js and spacers. The springs were too soft and the body roll was incredible.
just one comment that i haven't read yet in this long, over-blown thread (and perhaps it's in there and i missed it) but, do you not think the limit on the flex is because you guys bumpstop the ever-loving crap out of these 4 and 6 inch lifts? That HAS to be a contributor to the less flex shotts is talking about vs. his 100.
Common sense tells me that when you had a longer spring and a longer shock, you have more travel. But, you wusses don't want to mess up your flares, so you bumpstop the crap out of these things to limit the up travel. I know this has all been beat to death, so i'll stop.
um...no :D I had to run a little bit longer bumpstop with the 14" bilsteins because they were VERY long compressed. Even tho, you can see I still flex away with that. Even with the "L" shock I was flexxing pretty good and only had 2" bumpstops.
35's didn't rub at my 5"+ lift stuffed
This is the other side of that flex pic, me pulling on it to see how tipsy or free she was.
My rear wheels tuck all the way into the wheel wells, with the 2" bumpstops provided in the kit. The bumpstops stop travel before the shock is damaged, they have nothing to do with saving the tupperware flares. My truck flexes fine, I'm sure the 4" flexes the same as the spring height doesn't have anything to do with limiting extension. In the front, the only time I hit the bumpstops is if I compress both sides by hitting a bump at speed. The radius arms prevent the front axle from angling enough for one side to hit the stops while the other side is extended.
In short, the length of the spring has little to do with the amount of flex you get, especially if the springs aren't captured. It's all in the shocks- the 'L' shocks are longer, but since they are mounted in the same place as the stock shocks, the length not only makes the suspension able to extend further, it also limits how much it can compress before the shock bottoms out, destroying the shock. Ideally, you would use longer shocks, but move the mounting points further away from each other- giving you more extension and compression length.
-Spike
6" lift noticibly moved the rear wheels closer to the front of the rear wheel opening. Does anybody know by how much? Will lenghtening and or reshaping the lower control arms put the wheels back in the center position without rubbing? :confused:
I have no clearance issues w/ the flares. The tires hit the frame so I bumpstopped the rear to that point... actually, i bumpstopped to the max. compression of the shocks but the tire also hits the frame so I don't see the point in allowing more compression than the tire hitting metal.
If your shocks can take it, than you can use the wheelwell and frame as a bumpstop. Flares never entered the equation, at least w/ 35's on stock wheels.
Spike, that is an amazing pic! I would have chickened out long before that!
You could but then when your axles compresses the tires will most likely hit in the back of the fender well. Is there a technical reason you want the axle further back or are you just worried about aesthetics?
Pure aesthetic on a 37" tire setup. Maybe dropping the bracket or redoing the lower control arm might help center the wheel but not enough to rub at the back of the rear wheel opening. I already know what to do on a 39.5" + tires. :D
Wow, this thread is back from the dead :D
I was rereading this and want to clarify my comments - what you get on a lift that is heavily biased in travel to one direction is what I think of as "asymmetical suspension motion". If I have an 11" OME L shock with 6" up and 5" down, the axle can essentially pivot symmetrically on a 5" axis without any body movement at all, assuming no body or bumpstop contact within that range of motion and a spring that enables full travel (isn't too stiff), with only that last inch of travel occuring asymmetically (you are only compressing at this stage).
On the other hand, if I have 8" up and 3" down, then I am on a 3" symmetical axis with 5" of asymmetical motion where you can only achieve articulation through compression.
If the spring is too stiff to compress fully on the asymmetical compression side, you will effectively have a short travel suspension that could be moving on no more than the 3" pivot axis and therefore showing less travel than the mighty 100 series or a stock 80, and certainly substantially less than a 3-4" lifted 80 moving freely on a symmetrical 5" pivot axis. If the spring will allow the full compression, without premature wear, then you are as "flexy" as any other 11" travel suspension, but the travel is happening differently in a way that we might speak of in terms of feeling "balance".
This is of course totally irrelevant outside of the articulation demands of rock crawling - in straight line work, be it speed bumps or expeditions, you have little demand on that pivot axis.
I think a 6" lift should be less tippy than a 4" in many ways (not on off camber slopes, of course). If I have the greater overall suspension travel and a longer symmetical suspension motion, then the body should stay more level in twisty terrain assuming other factors like roll axis are materially equivalent. In severely off camber situations, more lift is really never your friend, but all in all if you add 2" of lift you should have more suspension to work with if you manipulate the shock travel, which is defintely a desirable goal in conjunction with tire size gains. Increase your track width to compensate for the extra height and there is no reason why you shouldn't be able to engineer a 6" lift that substantially outperforms the 4", and an 80 can use the extra clearance for sure.
If I wanted to run trails that really need a 37"+ tire, I wouldn't be rushing to keep my lift low on a rig as big as the 80. A good rock garden can make that point in a real hurry - I got myself so messed up the last time I was out that I almost rolled my "keep it low" 80. I'd have been way better off with the higher lift with a balanced long travel suspension (and some improved driving skills :eek:)
Questions about lengthening control arms to 'recenter' the axle come up occasionally, and I usually run away. I'll throw my $.02 in this time. :D
If you don't change the pivot point- the frame mount on the front arms, for example- then your axle hasn't moved back at all. When the suspension is compressed, the axle will be in the same place it was at stock height. The axle moves in an arc. If you lengthen the front arms to make the axle appear 'centered' with a lift, it will move forward on compression and could have interference with the front of the wheel opening, body mounts, bumper or whatever else is up there. Plus, you may run into issues with steering arms, driveshaft length, or other unforseen consequences depending on how much you move the axle.
There are good reasons to move an axle, but appearance isn't one of them.
-Spike
I too will update my comments about this lift.
I've rerun a few trails since I lowered my rear upper shock mounts by 1.5". The truck was more stable and the wheels stayed planted better due to the added droop.
I also mangled my DS rear quarter and tail light so I guess I will not sell this thing for some time. I need to get my investment back.
Meanwhile my comments about the new front Slee control arms stand true. I hate them....they drag....I got stuck on them. I think since I am keeping this truck I will slap the old arms back on and live with the incorrect caster (unless it then vibrates...then I live with the current setup as is).
I will say I luv the breakover!
They are slightly lower than factory arms. Our first and 2nd gen arms were pretty low profile, but the strength trade-off was not worth it. I would say that if you get hung up on them, maybe you need a better spotter :D
Oh, and you need bigger tires.
Can't get 37's....won't fit in the garage.
Spotter? Never needed one over that rock before. Hell, the 100 could make it down the thing without a spotter.
And to clarify...I'm not dogging your arms quality and/or value. They are an impressive product that serves the purpose for which they are meant. If my LX was a DD I'd shut up. :D
My stance is based on the fact this truck is a dedicated trail rig and I can live without perfect caster. This is why I'm thinking about swapping the arms out. I keep hitting the things on rocks and I'm afraid to try certain obstacles fearing the stuck. I'm high-centered on the arm here:
