Slee 4 or 6 inch?
I have been in Nashville for the past week and was hoping there would be some good pics when I got back. Thanks everyone! :beer:
Where are you in TN? I have the 4" with 35's and a friend has the 6" with 35's, we are both in Knoxville if you want to come and check them out in person.
Darren
HeavyD I'm in Cookeville. I may take you up on that offer sometime. Thanks
I really like the 6" and have 35's now, however, I plan on going to 37's soon...the springs really breakin well and get much for "flexy" I know there are a very vocal minority that LOVE to bash the 6" but I love the lift and haven't once regretted getting the 6.
shotts is just a bitter hater, you don't lift wheels any more with this lift than with other lifts. Spike wheels a lot of hard stuff as well as myself and haven't had any problems...I do run wheel spacers 1.25" front and 1" rear.
Flame away!!!!
I have the 6"/37" combo so if you are in ATL sometime look me up and you can check it out as well. I don't lift wheels as much as when I was J'ed and 35'ed...if anything I roll over things easier, less impact on everything, and more control (less momentum needed).
Are you running 3" bump stops? Thanks.
What backspacing are you running?
Thanks DAN
I have a set of 17" Sequoia wheels and 35" STTs that will be going on after I get the lift. Who do all of you recommended for wheel adapters/spacers? Are the ones from Marlin Crawler wheel "adapters" or "spacers"?
http://www.marlincrawler.com/htm/axles.htm
Thanks
ERG80
Thanks
ERG80
those are the ones I have...they are nice, just don't use wheel locks with them because the studs are slightly longer.
I got mine second hand from another Mud'er. They are 1" all around and they seem perfect to me. Any wider in the back and I think you are asking for trouble. My tires now rub the outer lip of the wheel well at full compression.
Flame away!!!!
Umm...that's a bizzare statement that basically says all suspensions are the same. I'm not saying it lifts a wheel a lot because I haven't run it - the "bash" you refer to is the fact that both kits run the same OME L shock, and on a 6" lift there isn't very much down travel left in the shock.
It does stand to reason that if the 4" kit on OME L shocks has 6" of up travel and 5" down, then the 6" kit has 8" of up travel and 3" down. In the case where you needed 5" of down travel to keep the wheel on the ground, then the 6" kit would lift a tire where the 4" wouldn't.
I absolutely buy the statement that the 4" kit has more balanced suspension travel, which is why I posted that if you are going 6" you should consider different shocks (or shock mount modifications) to optimize the suspension travel.
So you would need a 14 inch travel shock or space down the L shock 3 inches to run 6 inch lift correctly? Is this right?
First let me say that I fully intend on upgrading my shocks at some point so that isn't the basis of my question. But I do question the fact that that the static height of an 80 will determine the point at which it lifts a tire.
I wheel as often as anyone I know and virtually never lift a tire unless I choose to for a poser moment (ask anyone I wheel with). I also wheel in some of the most uneven terrain I've seen (Moab didn't come close to to taxing the limits of my suspension like SD does).
I will include a couple pics demonstrating the basis of my question. In the pic of me on the rock, are you saying that somehow a shorter spring could have kept my tire on the ground even though I "ran out" of shock? Even with a 4" lift spring, the shock would have maxed out and the tire would have lifted, no?
Secondly I question your 3" of downtravel measurement. I agree with the math but not the conclusion. I've included a second pic to show the static relationship between the tire and the body line of my rig. Bearing in mind that my tires are 34.9" tall unloaded, does that look like only 3" of droop? It doesn't to me.
I know this debate will be concluded no sooner than the one of which vehicle is superior off road but I had to throw in my .02
Alright, I can't help myself, I know ERG80 asked for no flex shots but I think everyone should take note of the relationship between my bumper and the trail with a 6" lift. It's not that bad in the pic but I hit pretty frequently (just look)
^^^ that is what I was saying, it has been discussed at length and documented that with swaybars and 80 series suspension design longer shocks don't give much more travel. I agree that OME shocks are not the best but.....
The 6" does give more breakover.
I have tossed the 4" and 6" lift idea around as well. I already have a Jeep J-20 with a 10" lift that can clear 40"s just fine and the TLC is a DD/family car.... I am swaying towards the 4" Slee lift as it's perfect for 35" tires and if I wanted bigger I could always do some trimming as a few pics here are proof of that. I also do freeways and would think that the 6" would be kind of tippy or more so than the 4", for emergency manuevers the lower the COG the better.
Also from reading the archives the Bilstein 7100 shocks are the shizznits and reweld the sway bar mounts before they snap off and take out something unexpected on the trails.
Flame away!!!!
No flame, but at Chiva Falls on Saturday I had two wheels off the ground in the same spot the 100 doesn't lift a wheel whatsoever. It's well documented that the N74L doesn't mate to the 6" that well.
Taller isn't always better. Finding a trail that a 4" and 35-inch setup 80 can't do is rare. Too many drawbacks with that extra 2" in my opinion.
Exactly. While I'm not a lift scholar I have wheeled my 80's at 2.5, 3, 3.5, 4, 4.5, 5.5 and 6" (really about 7 because I'm unloaded). The 6" is by far my least favorite.
Here is a 6" with Ls and 37s stuffing. No rubbage, and I am planning on going with a different shock at some point. 2" drops in the rear and none in the front as an FYI...
Those are some nice flex shots so i will let it go. Just this time.:rolleyes::D:D:):)
Wish I had my camera......but in this spot with my 6" LX450 I teetered on two wheels. I could idle there with the tires spinning so I had to lock to get out. Here's all four down in the 100. This does not make sense as we know the 100 has less overall travel. It did happen however in the real world two days ago. I even tried moving around in this spot thinking I was placed differently. My other 80 and my LX when lower soaked this right up and easier than the 100.
