Slee 4 or 6 inch?
Your 80 is too light...add more weight :)
TRUE! TRUE! I'm sure that factors into the equation. IF it was weighed down then the lift height would lessen and the up vs down travel would improve. Plus. the springs would compress easier. My bumpers are not lightweight (3/8 C-stamped steel) though they're not ARB or Slee in girth.
I think the weight thing is a major factor here. I have a HEAVY rig. The rubber skin alone is over 100 pounds...possibly more. I also have all the armor, full tool kit, etc added on. I have the Slee "heavy" 6" kit. If you are expecting a Slee heavy kit or even normal (all rated for well over stock weight) to flex...it won't as much as you expect. This WILL lead to more wheel stands inherently.
How different is the wheel base between the 80 and 100 John? That could be the reason the 100 has all 4 down and the 80 doesn't.
He says both 80s keep all 4 down with lower lifts.
-B-
Yes. If I had the springs at the same height though less rate I think that would help, HOWEVER....my shocks are fully extended. If the up vs down travel was correct the wheels would stay down too.
Shotts....I think that is your big problem. It's not the size of the lift but the fact that these springs are designed around a weighted 80 and yours is much lighter than most using this lift. You have softer springs on the 100 with MUCH more weight! I have noticed much better articulation as these springs break in, after about a yr my springs flex much easier than before!! If you think about it OME springs have a softer spring rate and are designed around a weighted 80. You would do better with much softer 6" springs on your spec'd 80.
Yes. Like I said above, the weight plays a factor, however, the shocks are extended so the suspension is cycling weight or no weight. The suspension is less of a wheel-lifter since we lowered the rear top shock mounts. That helped. The cure though is more down travel, or, stick the hweels way out like Slee did on his SAS 100 and don't worry about it. As it is the LX is not as stable as my 100.
It's not shock extension you should be paying attention to John, it's compression. Less weight means your springs aren't compressing as much, and you are relying on limited extension to make up the difference.
-Spike
-Spike
I've been doing what Mr. Slee suggests. Regardless, the issue is preference. I feel my LX and my old 80 was more capable than the LX is now. And the front arms gotta go.
I'm not suggesting that you should be happy with the way your truck performs. I'm just trying to explain why other people may be getting better performance then you are, and pointing out that the fact that your shocks being fully extended does not mean that you are using the full flex of the suspension.
-Spike
-Spike
A very important point that most overlook.
-Spike
X3 :D
Rear J springs plus 1" spacers = 5" lift Blistein 14" shocks...there is PLENTY of available flex/compression in the 5-6" range.
attachment.php
ShottsUZJ100 said:
Out of context. Nice try! :D
The thread is in regard to the Slee 4 or 6 inch kits.
Then why do you keep bringing the 100 series into this for comparison?? It has nothing to do with the 80 series 4 or 6 inch kits. The "J" lift is closer.
Ah, sorry.....it is relevant to the suspension cycling of my LX with the 6" kit. When my 100 out-flexes a modified 80 something's up.
Yeah, something is up. Your 80 series doesn't like you.
But seriously, I think reasonable explanations have been given for your lack of performance (flex wise). I believe 619TOY's rig is heavier than yours (cargo drawers, ARB w/ M1200, Hanna's...), and he REALLY has NO flex problems.
I think it's completely relevant :grinpimp: Your LX has 1" on that setup that I had. My 5" lift WAY out flexxes your 100.
The rear on those rigs are the same basic suspension setup...both link setups, you just are trying to cram a shock on there thats designed to work with a 3" lift. Try this...put a 6" lift spring on your 100 series and keep the same shock. Drive over the same spot and see what happens.
Hell take the shock off your 80 and go over that spot...either get some weight on that LX, or re-do your shocks/mount...then you'll be flexxing good.
