I think it's completely relevantYour LX has 1" on that setup that I had. My 5" lift WAY out flexxes your 100.
The rear on those rigs are the same basic suspension setup...both link setups, you just are trying to cram a shock on there thats designed to work with a 3" lift. Try this...put a 6" lift spring on your 100 series and keep the same shock. Drive over the same spot and see what happens.
Hell take the shock off your 80 and go over that spot...either get some weight on that LX, or re-do your shocks/mount...then you'll be flexxing good.
your truck was too light with 3.5", so your angles were off and you vibrated.![]()
Sounds like you should put that back on and enjoy since your 100 seems to be your preference for wheeling.
No! Back on topic.
How tippy is the 6"?
I'd be willing to bet that if you sold both your 80 and 100 you could scrape enough together to buy Christo's 100
Well added clearance is always nice. Plus it fits bigger tires. But at the cost of being tippier in off camber situations. What's the biggest tire you can fit with the 4"?Tippier than the 4-inch. Will you need that added clearance to run the trails you desire?
That's hilarious! My 100 alone is worth more than Slee's SAS 100.
My apologies, I have no idea what your truck, or Christo's, is worth.
-Spike
